DBoz Community Member
Posted: Sun Nov 15, 2009 5:11 pm Post subject: Sidkit? blaster grips - SOLD |
I have a set of blaster grips. These are possibly Sidkit made (as per andy's post below, they are about 4 inches from bottom to top, which is about 1/2 inch too short for the Coyle worldcon. SOLD
Here are some measurements of the grips:
Left side grip (on right in picture):
Height 4 1/8"
thickness 7/16"
width at middle bump 1 61/64"
width at top 2 3/16"
width at bottom 1 13/16"
distance from back to screw hole on bottom 1 3/16"
distace from back to screw hole on top 17/64"
diagonal distance between top and bottom screw hole 3 19/32"
Right side grip (on left in picture):
Height 4 1/8"
thickness 7/16"
width at middle bump 2 1/32"
width at top 2 33/64"
distance from back to screw hole on bottom 1 15/64"
distace from back to screw hole on top 1/4"
diagonal distance between top and bottom screw hole 3 35/64"
Please PM me if you are interested.
Thanks.
punctated Community Member
Posted: Sun Nov 15, 2009 6:13 pm Post subject: |
I will take the cylinder if it is still available.
Thanks
Thomas |
Posted: Mon Nov 16, 2009 1:02 am Post subject: |
The grips look like the ones for the first Sidkit all Metal kit.
ironfist Community Member
Posted: Mon Nov 16, 2009 3:25 pm Post subject: |
You might want to post actual measurements of the grips including thickness. _________________ The other Karl! |
Posted: Mon Nov 16, 2009 10:21 pm Post subject: |
I'll see what I can do about getting some measurements. |
