doc3d Community Member
Posted: Mon Dec 01, 2008 12:14 pm Post subject: |
I don't know man... mine seems to shoot real bullets just fine; a .full tilt .44 special 200 grain bullet going down the pipe doesn't seem to be an issue. But some of the doo-dads that stick out could be an issue-- the fake "laser" sight on the left side and the forward facing knob on the right. I've fixed the forward facing knob with internal steel reinforcing. Re the fake sight, I steel riveted mine into the *top* left side of the pewter Steyr receiver just above the cylinder shroud, it is NOT attached to the left cylinder shroud like the original prop, where it would surely wreck a pewter gun. The fake cylinder also has a copper tube in its center, so I don't think that puppy will go anywhere. That's one failure point for a pewter shroud I think I correctly assessed in advance and circumvented. But if the holster screws up something, those are the only possible two things. The structure is pretty well stabilized by having an actual steel/aluminum Bulldog pistol inside for attaching things to. For example the Steyr receiver screws right into the Bulldog's steel top strap. The decorative pewter grip cover screws directly into the Bulldog's aluminum grip frame, and at five points! The right side Steyr cylinder shroud screws into the steel frame. The left side Steyr cylinder shroud screws into the Bulldog's steel cylinder swing arm. The plastic Steyr magazine is secured to both the barrel's ejector rod cover as well as the steel leading edge of the Bulldog frame. Go back and have a look at my original post's photos. It's pretty strong.
I've started to rework the Bulldog's top rail, in anticipation of getting a functional laser sight installed under the Steyr receiver shroud (I won't be putting what looks to me like a horizontal mini-minaret in the center of the Steyr's front receiver plug). Already have a small cheapo laser made for guns (e.g. it can deal with shock and vibration) that should work well. When installed, this will make it the only PKD shooter in the world you can actually aim!
doc |
Posted: Thu Feb 26, 2009 11:26 pm Post subject: |
added from another thread for consolidation...
Offworld for measurement reference...
Offworld
A=7"
B=2 3/8"
C=4"
Coyle v3
A=7"
B=2 3/8" (2 1/2" with clip sticking out)
C=4"
Hartford
A=7 1/8"
B=2 3/8"
C=4 1/8"
Wilco
A=7"
B=2 3/8"
C=3 15/16"
SidKit Metal
A=7 1/4"
B=2 3/8"
C=4 1/16"
Rick Ross PKD-1
A=7 1/2"
B=2 3/4"
C=4 1/8"
Rick Ross PKD-2
A=6 3/4"
B=2 1/2"
C=4"
Coyle v3 vrs. Offworld...
neosporing Community Member
![](http://i.imgur.com/WpRBT8j.jpg)
Posted: Thu Jan 07, 2010 11:44 pm Post subject: |
isn't the offworld chambered in .357 and the coyle and sid in .44?
is the 'offworld' the MIM? |
Posted: Fri Jan 08, 2010 1:32 am Post subject: |
Yes, but the guns are pretty close in over all dimensions. I did omit the width though which I believe shows more variation in size. The MiM is another name for the Offworld because they were the main retailer for them. For more clarification on the terminology check here...
http://propsummit.com/viewtopic.php?t=1378
Posted: Fri Jan 15, 2010 2:18 pm Post subject: |
Thanks for the research and the sharing Andy. |
Gaff87 Community Member
![](http://img232.imageshack.us/img232/424/bullitt.jpg)
Posted: Fri Jan 15, 2010 4:09 pm Post subject: |
joberg wrote: | Thanks for the research and the sharing Andy. |
Seconded.
We're all more educated thanks to your dedicated work, Andy.
I'm gonna see if i can take the side on shots of my blaster tomorrow (or whenever possible)
I think mine is an early Coyle, maybe the same as your V3 Andy.
Will take some shots anyway.
Posted: Fri Jan 15, 2010 4:19 pm Post subject: |
I need to get a photo booth built so I can take some good close ups and detail shots of each.
oldzey Community Member
![](http://i.imgur.com/CsdfLiR.jpg)
Joined: 30 Apr 2007 Posts: 569 Location: Peoria, Illinois
Posted: Fri Jan 15, 2010 4:25 pm Post subject: |
You need some more blasters, Andy. |
Posted: Fri Jan 15, 2010 5:04 pm Post subject: |
oldzey wrote: | You need some more blasters, Andy. |
Can never have too many.
I need more, i know that. |
Posted: Sat Jan 16, 2010 5:30 pm Post subject: |
My brother took these pics for me...
The top shot is a littler blurred but it's better than the photo's i took ![Smile](images/smiles/icon_smile.gif) |
Posted: Mon Jun 27, 2011 1:29 pm Post subject: |
The pics doesn't show up on my side of the world ![Crying or Very sad](images/smiles/icon_cry.gif) |
SoloDallas Community Member
Posted: Sat Aug 27, 2011 9:26 am Post subject: |
Adding my Coyle 2009 WorldCon for reference.
Taking pics of my PRO shortly. |
prodigalson Community Member
![](http://i291.photobucket.com/albums/ll305/jonesthewhip/br.png)
Joined: 17 Aug 2011 Posts: 17 Location: Bedfordshire, UK
Posted: Sat Aug 27, 2011 10:03 am Post subject: |
Great pics man, superb detail, I really like the color of the amber grips most accurate shade I've seen so far. Can you see more of the exposed white wires from a different angle, or is that how it is / as you requested?
Cheers,
prodigal. _________________ "The Casablanca of science fiction movies". |
Posted: Sun Aug 28, 2011 6:58 am Post subject: |
Thanks Prodigal. I will take some more pics of it. This is how I had asked Mr. Coyle to do it for me
Here's the PRO:
E18G6625 by SoloDallas, on Flickr
E18G6630 by SoloDallas, on Flickr |
Posted: Sun Aug 28, 2011 10:53 am Post subject: |
I especially like the way these latest pics of your Pro emphasize the glossy finish on the chamber housing. Beautiful and very accurate IMHO.
Posted: Sun Aug 28, 2011 11:39 am Post subject: |
Thanks Prodigal!
I have been a pro photographer in the past, though these are shot outside (obviously, not in the studio).
However, I always try to replicate the real look of the items (3D, light, etc.)
Fil ![Smile](images/smiles/icon_smile.gif) |
Bucky Cat Community Member
![](http://propsummit.com/upload/1073/dsc01073.jpg)
Posted: Thu Aug 01, 2013 10:46 am Post subject: |
I wanted to add to the mix.
Here is my Tomenosuke PRO kit. And a steel barrel from DaveG. "Precious photos" are from Kurtboy here on the board. They seem to belong together.
The last piece of this puzzle will be new amber grips from Proper and I can close the book on this prop I've wanted since 1982. (I don't think the full size spinner is going to happen.
Ted. _________________ In space no one can hear you scream. But you can always text. |
jontom Community Member
Posted: Sat Mar 08, 2014 11:00 pm Post subject: |
Test fitting of all the parts before I build the trigger groups! I airbrushed clear red on the backs of the grips to get a more amber color, quite happy with how they turned out.
-John
![](http://propsummit.com/upload/744/photo_2.jpg) |
Crowley Community Member
![](http://propsummit.com/upload/518/seedav2.jpg)
Joined: 28 Nov 2008 Posts: 45 Location: Suomi, ulkomaanpellet!
Posted: Sun Mar 09, 2014 3:02 pm Post subject: |
I'm curious, can anyone provide the measurements for Rick Ross' "magnum" model? Or is that already listed here? |
