Mad Max RVS radio build
PostPosted: Sun May 23, 2010 6:55 am    Post subject: Mad Max RVS radio build Reply with quote
My Mad Max collection is pretty much based around diferent aspects of the cars and ive finally started putting together thr RVS radios used in the MFP cars.
These scratch built units always fascinated me and i think thy pull off the future look while staying in the time.
Heres the progress so far, when the cover box is finished, will set the lights up on a movie correct chase pattern.
PostPosted: Mon May 24, 2010 5:04 am    Post subject: Reply with quote
Very cool, Tim!
What material is it made of? (If you don't mind me asking)
Looks killer.
Neil
PostPosted: Mon May 24, 2010 7:12 am    Post subject: Reply with quote
Looking good Tim (or should I call you Light Master?)
PostPosted: Mon May 24, 2010 8:51 am    Post subject: Reply with quote
Thanks guys,
Its made of plywood Neil and sprayed with aluminium spray paint then covered with a satin clear coat, glad you like it as well.
J, here is a picture of a professionly made version for the replica car market, it runs about $600US, so far mines cost about $30.
I would like to have a "one piece" cover box as per the pro version, plastic or metal, what would be the process?
I can always box up four bits of ply to do this job but i dont think it would be as clean as the one piece.
Hasenbrau
PostPosted: Mon May 24, 2010 5:28 pm    Post subject: Reply with quote
Very very cool Tim, Keep us posted.
PostPosted: Tue May 25, 2010 6:58 am    Post subject: Reply with quote
Tim, you can work with High Density Particle Board (great to glue, screw, sand, paint, etc). After the box is made out of that board, I would slap thin plastic sheets on top (with contact cement) and paint it with a nice alu spray-paint (like you did your BR suitcase).
PostPosted: Sun May 30, 2010 7:42 pm    Post subject: Reply with quote
Thanks J
Forgot i had this. We have these at work and they do the same gig as the RVS. The real one is called RTS.
PostPosted: Wed Oct 06, 2010 8:41 pm    Post subject: Reply with quote
Finally got this one finished, stoked with the end result. Still working on getting some audio straight off the movie to play out of it and think ive found the best way, still workin on it.
PostPosted: Thu Oct 07, 2010 7:14 am    Post subject: Reply with quote
Very good results here Tim! Cool Love it when somebody tackle the "less known/popular props" in a movie.
propsjonnyb
PostPosted: Thu Oct 07, 2010 1:04 pm    Post subject: Reply with quote
Really love the retro feel , excellent work sir ! You could dump the WAV audio file on a recorder circuit like the one JT did for the Alien Derelict build - I think its a Radio Shack part , but any type of recorder circuit would do . I really do like it - pity I don't have the car to mount it in!! Shame !!!
PostPosted: Thu Oct 07, 2010 8:18 pm    Post subject: Reply with quote
Thanks very much guys.
Thats pretty much how im going to do it jonny, just trying to find a good, free program that will lift the dialog from the movie, theres a first class editing set up at
work but cant get access to it.
