Repair help on Off World upper reciver....
rikarus
PostPosted: Fri Nov 12, 2010 5:24 pm    Post subject: Repair help on Off World upper reciver.... Reply with quote
well I am a dumbass, thats how this starts. I have been trying to revitalize a MiM blast I picked up built in 2006.... one thing after another has set me back, but with some patience and redo's it was coming back together.
I bought the off world mag with LEDs, and the metal upper reciver. Just got them today.
Well needless to say the second I tried sliding the MiM bolt in I broke the metal on the back right side. It's a thin area and I was being gentle...but apparently I am a bigger clutz than I thought. Current;y I am trying to salvage the part by using epoxy to re-attach. and then I am goign to get the right kit for the upper.....eventually.
So can anyone tell me if epoxy will wor, or could I solder this area to repair it?
Thanks!
PostPosted: Sat Nov 13, 2010 9:52 am    Post subject: Reply with quote
I feel your pain, if that piece is pewter I would not recommend any soldering since the pewter has a low heat point. As for epoxy, you can always ask your local hardware shop what is the best one for metal.
PostPosted: Sat Nov 13, 2010 7:23 pm    Post subject: Reply with quote
The offworld isn't pewter, it is pot metal. Should handle soldering, but a good metal filled repair epoxy should work better and be easier to use.
propsjonnyb
PostPosted: Sat Nov 13, 2010 8:33 pm    Post subject: Reply with quote
Metal epoxy would be the best bet , but I suspect the part might be two thin to join directly , I would suggest using a thin piece of plasticard used as a mount cut to size then smooth a thin film over the card and then mount the pieces back onto the card use the epoxy to join the break and fill any gaps.
rikarus
PostPosted: Sun Nov 14, 2010 10:43 am    Post subject: Reply with quote
Ah cool I will try this, it is too thin at this point, and I guees it's gonna live in the box till I get the rest of the blaster to go with it. Tis a shame it wouldn't go on the MiM.
PostPosted: Mon Nov 15, 2010 12:06 am    Post subject: Reply with quote
Where did you buy it from? You might ask them directly, and let them know it broke because you had problems putting it onto the gun you bought it for. They may be willing to replace it.
rikarus
PostPosted: Mon Nov 15, 2010 9:56 am    Post subject: Reply with quote
ebay from offworld.
PostPosted: Mon Nov 15, 2010 11:29 am    Post subject: Reply with quote
I sent you a PM with the Offworld address I have. They are the ones who made it and sold it to Monsters in Motion.
PostPosted: Mon Nov 15, 2010 2:24 pm    Post subject: Reply with quote
Any pics of the actual damage to share? It's always helpful to see the break.
I have no experience with the offworld, but I've had to repair some broken denix guns in the past.
rikarus
PostPosted: Mon Nov 15, 2010 2:47 pm    Post subject: Reply with quote
Yah i will put some up when i get home tongiht.
Thanks for help.
