Ozwepaie Community Member
Posted: Wed May 22, 2013 7:47 pm Post subject: |
And yes. I did name my Tome Pro World-con, Selma.
I'm that f**kin' guy!! _________________ Que la Force soit avec toi |
Posted: Wed May 22, 2013 7:53 pm Post subject: |
"from now on, you maggots will will sleep your rifle. You will give your
rifle.. a girls name! Because this weapon is only pussy, you lady's are
going to get!
Your days of finger banging ol' Mary Jane Rottencrotch... ARE OVER!!"
-Heartmen, FMJ _________________ Que la Force soit avec toi |
jakob2121 Community Member
Posted: Wed May 22, 2013 8:38 pm Post subject: |
I finally got a chance to start working on mine. Definitely cold cast, and it works a lot like a pencil lead - the black isn't a coating, it's the mix. There's enough "stuff" in the plastic that you can go flat black to shiny dark gray depending on how it's sanded, and if you weather it lightly the shiny will look metallic against the black. I'm going the same route as Don - bluing the barrel and lightly weathering the body, to try to match the prepro blaster pics. |
Posted: Wed May 22, 2013 9:05 pm Post subject: |
I'm interested in the size of this piece. Looking at the pictures over on RPF the Tome kit is very nearly the same size at the Sidkit - indeed, the grips are actually bigger than the Sid.
I was always under the impression that the Sid was bigger than the original but it seems this is not the case??
It would be great to see comparative shots between the Coyle, Sid, Ross. Offworld and the Tome.
Lovely kit and thanks to Mune and the team for making it available..
Highest regards
MARK _________________
Photech Community Member
Posted: Wed May 22, 2013 11:43 pm Post subject: |
What ate the dummy rounds like? Real or plastic? _________________ No! 4, 2 - 2, 4. |
Posted: Thu May 23, 2013 1:01 am Post subject: |
I compared parts of it to a real Steyr magazine and Bulldog grip frame, and it seems to be very slightly smaller. By about a millimeter overall. The screw holes also do not match up. The Bulldog 44 cylinder does fit though, and matches pretty well in size. I wonder if there could be some variation on the CA Bulldog grip frames over time.
munegumi@event.co.jp Community Member
Posted: Thu May 23, 2013 3:21 am Post subject: |
I am glad you guys like it. Mune
Staar wrote: | I'm interested in the size of this piece. Looking at the pictures over on RPF the Tome kit is very nearly the same size at the Sidkit - indeed, the grips are actually bigger than the Sid.
Highest regards
MARK |
Posted: Thu May 23, 2013 9:33 am Post subject: |
Photech wrote: | What ate the dummy rounds like? Real or plastic? |
They're metal reproductions. |
Posted: Thu May 23, 2013 10:06 am Post subject: |
Seems that we have a winner in that kit (Oz, please emote a little more ) I do that with designs/Art that really touch me (staring at it for months!) and yes, I don't think my wife understands either
Looking forward to see those mounted properly (calling DaveG)and the different takes you crazy guys will produce. |
Posted: Thu May 23, 2013 11:27 am Post subject: |
I'm having Kotofett make me a MR style case.
But I plan to use the Dave G stand. to hold the gun.
I'm just waiting to have the stand in hand. Before I
decide how big I want the case to be.
In the mean time I keep it in the box. But it finds it's way to
the "turn table" at least once a week.
& Jo, are you serious about the emotes?
not sure if you're just busting my balls about my 4 Guinness in posts.
Posted: Thu May 23, 2013 1:48 pm Post subject: |
Putting mine together, and I noticed I got two slotted screws instead of a slotted screw + weaver knob. So if anybody gets two weaver knobs, let me know! |
Posted: Thu May 23, 2013 1:52 pm Post subject: |
Ozwepaie wrote: | I'm having Kotofett make me a MR style case.
Could I get in on a few of those cases too?
How much are they going to run?
Thanks
S |
Posted: Thu May 23, 2013 4:29 pm Post subject: |
I'm making a lightsaber for it. I know he'll make them. I'll just have to
find out how much? _________________ Que la Force soit avec toi |
Posted: Thu May 23, 2013 4:38 pm Post subject: |
Nah Oz...just kidding Besides, I cannot kid about Guinness, that would be...unheard of
Looking forward to that box and that Tome together. |
Posted: Fri May 24, 2013 12:56 pm Post subject: |
Has anyone built theirs up enough to see if the steyr lever can be pulled back? Mine hits the receiver and will not travel any further. |
Posted: Fri May 24, 2013 1:56 pm Post subject: |
I have - of you're talking about the Steyr receiver, I had to file a little bit of burring off the elbow part of the slot to get it to work. It wouldn't budge past, but it only took a very little bit of filing to get it smooth as butter. This thing has some very tight tolerances.
Speaking of, I haven't had a chance to finish the weathering, but this is about 3 hours worth of work. This kit really is fantastic.
colinfair Community Member
Posted: Fri May 24, 2013 3:01 pm Post subject: |
hi all
just got mine this evening wow great workmanship well done team mune.
clutch you beat to that question so we are ok on that sorted.
did anyone pick up the .44 rounds are not full length because the cylinder is partly blanked off.
colin |
Posted: Fri May 24, 2013 3:16 pm Post subject: |
Thanks for the file tip . Too much to take in right now. I didn't notice the bullets either . |
Posted: Fri May 24, 2013 5:02 pm Post subject: |
TFS Jakob...good work Seems an easy kit to build. |
DonParker Community Member
Posted: Fri May 24, 2013 7:05 pm Post subject: |
Nice work Jacob, mine is almost done , just
waiting for the paint on one of the side covers
to dry. My biggest problem is not waiting long
enough and my finger prints get into it.
I noticed the bolt was somewhat tough to pull
back on mine as well but it seems to be alright
now.
I did have to lathe some of the shoulder off
the rear screw for the butt plate, it was to long. |
