Sanding Tomenosuke barrel for metal look
PostPosted: Fri Oct 10, 2014 7:00 am    Post subject: Sanding Tomenosuke barrel for metal look Reply with quote
Has anybody actual experience with using this guide?
https://plus.google.com/photos/108281134102221018453/albums/5913876521088809041?banner=pwa&authkey=CKPMzNOEpqjJQQ
Apparently it should be possible to just sand the barrel, and then it turns into metal?!?!
My appologies if this has been covered already...
PostPosted: Fri Oct 10, 2014 4:41 pm    Post subject: Reply with quote
There's metal powder in the plastic. It definitely creates a metal like sheen with enough sanding and polishing and can be blued with casey super blue as a few people have done. Never tried it myself.
PostPosted: Sat Oct 11, 2014 3:23 am    Post subject: Reply with quote
Interesting, thanks hirohawa ... Perhaps I should give it a shoot...
VFX Freak
PostPosted: Sun Oct 12, 2014 3:53 pm    Post subject: Reply with quote
I tried this as an experiment on my barrel before I cut it off and replaced it with one of Dave G's steel barrels. It does work. The key is to dry sand it. If you wet sand it you will never get the metallic patina you need. Dry sand with 400 and 800 or so, and then finish with either the gray Scotchbrite pads or 0000 steel wool. Then you can use the Perma Blue and you'll get a pretty decent blued steel look.
"I shoot better when I move." - The Sundance Kid
PostPosted: Sat Oct 18, 2014 1:36 pm    Post subject: Reply with quote
Thanks, think I'll try this before cuttting it off.... Perhaps it'll look good
