Posted: Fri Oct 10, 2014 4:41 pm Post subject: |
There's metal powder in the plastic. It definitely creates a metal like sheen with enough sanding and polishing and can be blued with casey super blue as a few people have done. Never tried it myself. |
Posted: Sat Oct 11, 2014 3:23 am Post subject: |
Interesting, thanks hirohawa ... Perhaps I should give it a shoot... _________________ Monsieur, azonnal kövessen engem bitte |
VFX Freak Community Member
Posted: Sun Oct 12, 2014 3:53 pm Post subject: |
I tried this as an experiment on my barrel before I cut it off and replaced it with one of Dave G's steel barrels. It does work. The key is to dry sand it. If you wet sand it you will never get the metallic patina you need. Dry sand with 400 and 800 or so, and then finish with either the gray Scotchbrite pads or 0000 steel wool. Then you can use the Perma Blue and you'll get a pretty decent blued steel look. _________________ "I shoot better when I move." - The Sundance Kid |
Posted: Sat Oct 18, 2014 1:36 pm Post subject: |
Thanks, think I'll try this before cuttting it off.... Perhaps it'll look good
VFX Freak wrote: | I tried this as an experiment on my barrel before I cut it off and replaced it with one of Dave G's steel barrels. It does work. The key is to dry sand it. If you wet sand it you will never get the metallic patina you need. Dry sand with 400 and 800 or so, and then finish with either the gray Scotchbrite pads or 0000 steel wool. Then you can use the Perma Blue and you'll get a pretty decent blued steel look. |
