‘Give me about twenty minutes’ – ALIEN – Incinerator Unit
Goto page Previous  1, 2, 3 ... 9, 10, 11 ... 13, 14, 15  Next
PostPosted: Tue Apr 28, 2015 6:56 pm    Post subject: Reply with quote
Oh yes, one heck of an update mate! Love it already Cool
PostPosted: Thu Apr 30, 2015 2:40 pm    Post subject: Reply with quote
Thanks joberg.
I've managed to do a bit on the flamethrower this week.
I had a go at the detail just behind the top vent. As with some of the other details on the body I'm aiming for the feel rather than a true copy of the parts.
Here is a reference photo of the detail in question. I'ts enlarged from a pictures I took at the Propstore exhibiton last year.
This is what I have come up with so far pieced together from ABS, Styrene and kit bits. Not very pretty!
And here with a coat of primer.
Placed in position. I think with a few coats of thick paint and some weathering it might do.
Moving back to the white tank, I milled a shoulder on the end of the hex steel bar. this is to reduce the visual weight protruding from the bottom of the tank.
Colin
Ripley: What's it key on?
PostPosted: Thu Apr 30, 2015 6:17 pm    Post subject: Reply with quote
Difficult to make-out the greeblies on that particular piece Colin Confused , but I think that you're close from the original.
Keep up the great work!
PostPosted: Mon May 25, 2015 1:02 pm    Post subject: Reply with quote
I've managed to do a bit more on the flamethrower this past week.
I turned the detail in the ABS Pastruct pipe which sits under the Hornby piers on the right side.
Here it is laid out against the drawing and reference photo.
Here assembled with the 90 degree bends.
Here in position.
I also turned the rest of the sections of the Antenna that goes on the left side.
Here are the individual sections.
I plan on adding some extra details onto some of the sections. I want to mould all these sections so I can run some metal through them to strengthen then up.
More soon!!
Colin
PostPosted: Mon May 25, 2015 8:04 pm    Post subject: Reply with quote
Very good research and resulting work Colin Cool Yeah, that antenna would bend real fast without some kind of metal rod inside. Good call
PostPosted: Tue May 26, 2015 2:15 am    Post subject: Reply with quote
Great work Colin !!!
Love these pipes a lot, they look perfect !!!
PostPosted: Tue May 26, 2015 3:35 pm    Post subject: Reply with quote
Thanks joberg and Fred for your comments.
Hopefully there will be more regular updates in the coming weeks. I'm really trying to keep up the momentum this time.
It's so easy to fall asleep at my desk on a lunch time!
Colin
PostPosted: Tue May 26, 2015 7:37 pm    Post subject: Reply with quote
Lay-off the carbs mate
PostPosted: Sun Jun 07, 2015 4:51 pm    Post subject: Reply with quote
Time for an update.
I bought the Saturn V kit for the engine part for the lower detail on the white tank.
I decided to mould it as the kit was rather expensive!
I moulded some of the antenna parts too (the ones I have finished patterns for) so I could cast them with a hole running through them to mount on the steel support rod.
I dropped some fine brass rod into the thin sections to give them a bit more strength.
I trimmed off the bottom part of the engine.
Here it is glued onto the main detail bit.
I did a bit of filling and priming on the pattern for the white tank.
I added some extra detail to some of the antenna parts. Unfortunately I added them to the wrong end on the larger one. So I have to strip the detail off and do it again!
Because I sunk the bent side pipe into the side panel I had some gaps I wanted to fill.
So I did a filler fit!
Trimming off the excess.
Here are the grips in progress. I've buffed the edges but left the sides sanded.
Here's a shot of the left side with the antenna taking shape and more details added.
Here's the right side with the the pipes finally glued into position.
I'm getting there.
More soon.
Colin
Harry Harris
PostPosted: Mon Jun 08, 2015 3:15 am    Post subject: Reply with quote
It's a good job I'm at work and wearing steel-toecapped boots or my chin would hurt my foot!
I love this thread!
Harry
PostPosted: Mon Jun 08, 2015 7:20 am    Post subject: Reply with quote
Thank you Harry.
PostPosted: Sat Jun 13, 2015 4:07 pm    Post subject: Reply with quote
Same as Harry, totally blown away by this new update !
Well done, Colin !
PostPosted: Sat Jun 13, 2015 8:25 pm    Post subject: Reply with quote
What an update indeed! It was worth the wait Cool Keep up the great work as always.
PostPosted: Sun Jun 21, 2015 4:53 pm    Post subject: Reply with quote
Thanks for the comments guys.
Here's another update.
I wanted to add a bit more detail to the white tank addition. This is my reference below. What I'm trying to recreate is probably a build up of paint on a surface!
So I came up with these curved pieces on the right to add to the sides.
Like so.
I've also drilled the entry hole into the top vent for the smaller pipe on the right side.
One detail I've yet to make is the underside front detail shown here in one of Harry's photo's.
Using the laser cut parts on the left in the picture of laser cut parts above I came up with this.
Here primed and in position.
I moulded the part and cast it in fast cast.
I noticed some new detail recently on the left side. The domed ends on the half cylinder.
So I turned up a pattern, moulded it (casts above) and added it to the existing cast.
Here glued in position with the underside detail.
I finally cast the rest of the antenna parts. I embedded some M3 bolts into the cast so I can bolt it onto the left side.
Here it is dry fit assembled.
I'm undecided whether I should add more detail to the bottom of the unit. There is definitely more stuff there which has fallen off through use.
Just preparing the tank to be moulded in glass fibre. I laser cut a bed at the half way point to cut down on the amount of 'claying up' around the piece. I hope to get onto this soon.
In the next update I should have the antenna fixed in position along with the rest of the details on the body. This means I can glue on the left side and prime the whole body.
I'm also going to have a go at making a copper cover for the top vent rather than the vac form one I have.
Still lots to do but making steady progress.
Colin
Pro Mod
PostPosted: Tue Jun 23, 2015 5:22 am    Post subject: Reply with quote
Looking great Colin!
I think the rectangular piece with the hole that you've scratchbuilt, may have been a part from the 1:72 scale Hasegawa Morser Karl railway gun.
http://www.britmodeller.com/forums/index.php?/topic/75382-moerser-karl-on-railway-carrier/
PostPosted: Tue Jun 23, 2015 7:31 am    Post subject: Reply with quote
Thanks Pro Mod.
Yes that part is definitely a contender.
In fact there is a choice between a couple of the parts.
Quite an interesting kit. Lots of good pieces.
Colin
PostPosted: Tue Jun 23, 2015 2:06 pm    Post subject: Reply with quote
I got the antenna mounted on the left side today along with a few of the 'smoke bottles' running along the top of the brass square box section.
It looked like there used to be three smoke bottles, so that's what I put on. Also they are the right way round rather than upside down like the ones below (not stuck on yet)!
Here are a few pictures of the progress.
Colin
PostPosted: Tue Jun 23, 2015 4:38 pm    Post subject: Reply with quote
This kind of prop is very deceiving. At first glance, you'd think it's simple, but the more you look at it, the more complicated it becomes.
(A little like the V.K. machine).
It's nearing its final shape...eager to see it finished Cool
PostPosted: Fri Jun 26, 2015 1:50 am    Post subject: Reply with quote
Bravo Colin, another great update, can't believe what you went through to re-create this...
One thing is certain, it's going to be AWESOME once completed !!!
PostPosted: Sat Aug 01, 2015 4:24 pm    Post subject: Reply with quote
joberg and Fred, this is a little late but thanks for your comments.
I've had quite a bit on recently so the flamethrower has had to take a bit of a back seat.
Things have calmed down a little and I've been able to return to it.
I'm getting close now to fixing everything together more permanently.
I wanted to change the top vent cover. My original go at it (below) was a vacform over a wooden former. It looked okay but I had a lot of webbing around the base that made it weak.
So I decided to have another go at it. I really wanted it to be covered in metal. I tried folding metal over the former but I didn't really have the right tools. Also it wasn't giving the right look.
So I came up with this approach using copper and aluminium sheet. I cut some spacers and double sided taped them onto the sides of the former.
I then heated the metal and bent it over the former. I then trimmed the metal back to the spacers.
I then removed the spacers to create a recess. Using different thickness' of aluminum I created a void to slip the brass square mesh into.
The wider piece when glued on traps the mesh in place.
The copper sheet bent over the top creates a step on the edge.
I just need to glue the copper down now!
Even though I like the pad eye's I bought to hang the strap off they are not as screen accurate as they could be. So I might try fabricating some.
Colin
Page 10 of 15
