mspaw Community Member
Joined: 18 Mar 2007 Posts: 234 Location: Sacramento CA
Posted: Wed Nov 11, 2009 1:50 am Post subject: Machined Replacement Barrel For the SidKit |
Hey gang-
So I had threatened in the site rod thread that I was looking into doing a short run of steel replacement barrels for the Sidkit. Ive worked up a prototype that I’m fairly happy with and wanted to share some quick pics. It will be great to hit with some gun blue and as its machined it is soooo much tighter than the casting which it replaces. It is drilled and tapped to match the M3 and M6 cap head machine screws that come with the kit. Ill most likely be adding a replacement for the M6 screw as the kit screw is too long and broaches the barrel. Also Ill be adding a steel standoff post as the kit version has a scallop that sits conformal to the curve of the barrel and in the actual prop its just flat.
Let me know what you think.
Here are some quick pics that ill update/replace later this week with more details ad something a lot less blurry
-Michael |
Posted: Wed Nov 11, 2009 2:11 am Post subject: |
I think I may have to be in on this one too.
Posted: Wed Nov 11, 2009 3:11 am Post subject: |
Great plan here mate!!
Yep.. I'm interested too. A point to consider is that the Sidkit barrel is too short. Would it be possible to make the length more accurate?
WorldCon:
SidKit:
seesinsilhouette Community Member
Posted: Wed Nov 11, 2009 3:16 am Post subject: |
| im definately in! probs for 2 depending on cost. great work once again! |
Posted: Wed Nov 11, 2009 6:02 am Post subject: |
I am interested as well.
Thanks |
Cottonball Community Member
Joined: 14 Aug 2009 Posts: 30 Location: Pennsylvania, USA
Posted: Wed Nov 11, 2009 7:41 am Post subject: |
I am interested as well! Likely for a couple of 'em.
Eric |
Posted: Wed Nov 11, 2009 11:25 am Post subject: Machined Replacement Barrel For the SidKit |
Starr-
Fantastic info. Do you or anyone else happen to have have a better mesurement? I can get it much closer no problem.
Thanks!
-Michael |
Posted: Wed Nov 11, 2009 12:51 pm Post subject: |
Been playing around trying to put the metal sidkit barrel in a Hartford to see if this machined one fits. It's very slightly wider but shouldn't b too much trouble to fit it.
Any chance of a cut down one for the snub nose? I can post measurements
mike |
Posted: Wed Nov 11, 2009 1:12 pm Post subject: Machined Replacement Barrel For the SidKit |
Yeah interestingly enough I measured the length against Rich’s for the prototype, but if we can come up with a length that is dead on to the original I’m on it.
Also I’m happy to do a shorter version for the snub but ill need to get measurements from you. |
Posted: Wed Nov 11, 2009 4:29 pm Post subject: |
Very cool work. I so love seeing these machined parts!
In for 2. _________________ I don't have enough blasters! |
Photech Community Member
Posted: Wed Nov 11, 2009 6:05 pm Post subject: |
I wonder If I could fit it to an offworld?
That would be sick. _________________ No! 4, 2 - 2, 4. |
Posted: Wed Nov 11, 2009 6:09 pm Post subject: Machined Replacement Barrel For the SidKit |
Get me a drawing with the mesurements for the offworld and im sure it can be done.
-Michael
p.s. I guess what I ment to say is im not sure of the specifics of the kit as i dont have one so id be happy to come up with something we would just need ot make sure that everything is taken into account.  |
punctated Community Member
Posted: Wed Nov 11, 2009 6:32 pm Post subject: |
I would be in for an OffWorld barrel.
Thomas |
ironfist Community Member
Posted: Wed Nov 11, 2009 8:26 pm Post subject: |
The issue with the off-world is mounting steel to cheap plastic. _________________ The other Karl! |
Posted: Wed Nov 11, 2009 8:32 pm Post subject: Re: Machined Replacement Barrel For the SidKit |
| mspaw wrote: | Starr-
Thanks!
-Michael |
Mate --
I know Beastmaster did a lit of measuring for his brilliant SidKit build so maybe he will have a better idea of what the actual difference is.. _________________
Posted: Wed Nov 11, 2009 9:09 pm Post subject: |
| Quote: |
I was about to mount a steel rod/pipe inside my plastic barrel to give it more weight, it shouldn't be to hard to attach the barrel to this. May have to re-enforce the frame a bit and use some epoxy but It should be possible as the front will be supported by the post. Have to check tonight when I get home. _________________ No! 4, 2 - 2, 4. |
Posted: Fri Nov 13, 2009 10:10 pm Post subject: Machined Replacement Barrel For the SidKit |
Last night I was able to machine up a good number of blanks and bore them out. I’m thinking I’ll do a run of thirty to fifty depending how interested everyone appears to be. Id like to have 10+ ready for shipping tail end of next week.
-Michael |
Hasenbrau Community Member
Posted: Sat Nov 14, 2009 2:01 am Post subject: |
| Great work. I would definitely be down to snag 2 of these off you. |
Skin-Job Community Member
Posted: Sat Nov 14, 2009 4:02 am Post subject: |
I'm in for 2 machined barrels, the more accurate long version.
Karl |
Posted: Sat Nov 14, 2009 4:03 am Post subject: |
Fantastic news,roll on the list, I know I'll b after at least 2. I'll also measure up the snub nose today
mike |
