ironfist Community Member
Posted: Sat Feb 20, 2010 2:10 pm Post subject: Prop Summit Edition RACProp Builds/show off thread. |
Post some pictures people!
Also questions and advice on your builds please direct to this thread. I'll be asking that the thread in the prop shop be deleted when everyone has there's. _________________ The other Karl! |
Posted: Sat Feb 20, 2010 2:18 pm Post subject: |
Great idea, and I will watching and here to answer questions and help as needed as best I can.
As some of you are finding out I included the weaver knob as well, so you can build either version. (It may take a little extra work to fit it...)
jameth Community Member
Posted: Sat Feb 20, 2010 2:33 pm Post subject: |
| racprops wrote: | Great idea, and I will watching and here to answer questions and help as needed as best I can.
Rich |
Which knob is more SA? |
Posted: Sat Feb 20, 2010 2:37 pm Post subject: |
Well as a few of us have found there is no shot within the film with the weaver knob.
All shots of that side show the screw.
ItalianNinja86 Community Member
Posted: Sat Feb 20, 2010 5:56 pm Post subject: |
| I got a question whats the best way to go about doing the ammo |
Posted: Sat Feb 20, 2010 6:16 pm Post subject: |
Well for those within the USA I am sending real unloaded Brass and hollow points bullets.
For those overseas we are casting up Plastic Rounds.
All 44s of course.
| ItalianNinja86 wrote: | | I got a question whats the best way to go about doing the ammo |
Posted: Sat Feb 20, 2010 6:22 pm Post subject: |
I was just wondering if only the shell is suppose to go into the chamber
or can we put the hollow point in the shell (to form a complete round)
and if so what was the best process? |
Posted: Sat Feb 20, 2010 6:31 pm Post subject: |
yes you can put them together.
Posted: Sat Feb 20, 2010 6:36 pm Post subject: |
| any advice rich or is it as simple as heat the shell insert the hollow point then cool the shell so it shrinks again? |
Posted: Sat Feb 20, 2010 7:30 pm Post subject: |
Worst than that.
In most cases just push the bullet into the brass, or at worst a little tap with a rubber hammer... Gently.
In fact you may want to put in a filler and glue them together.
Posted: Sat Feb 20, 2010 7:40 pm Post subject: |
| alright thanks for the advice Rich |
Posted: Sat Feb 20, 2010 7:49 pm Post subject: |
Your welcome...
Posted: Sun Feb 21, 2010 8:28 am Post subject: |
A special note.
I buy the brass rounds at a gun store in bulk.
They are in open bins and I have to scoop them out and count them.
I was just PMed that a couple of 44 MAG rounds was sent out and yes these are too long for the 44 special chambers.
Please check your brass; it will say MAG or special on the bottom.
Please email me if you got any MAG rounds so I can replace them with 44 special brass in the mailing of the extra parts I will be mailing out this week..
Thanks for your understanding.
Posted: Mon Feb 22, 2010 3:55 pm Post subject: |
Can someone please snap a few pics of the kit laid out???
Thanks |
Posted: Tue Feb 23, 2010 10:53 pm Post subject: |
OK here is the first draft. Of some of it.
http://s922.photobucket.com/albums/ad67/racprops/Propsummit%20SE%20Blade%20Runner%20kit%20instructions/
If someone has the program to create short URLs please do so…
OK Check these out, tell me what you think ask questions etc.
Please forgive any typos (I don’t mind you pointing them out I will try to fix them) I get a little punchy doing all these pictures.
Posted: Tue Feb 23, 2010 11:16 pm Post subject: |
Actually Rich, that album is empty. I can see some of your other albums, but it says that one is empty.
Posted: Wed Feb 24, 2010 12:49 am Post subject: |
Hey Rich since you stated this is only a first draft I was wondering if you
were gonna add what drill bits and taps get used for each hole in the final
draft |
Posted: Wed Feb 24, 2010 6:07 am Post subject: |
| andy wrote: | Actually Rich, that album is empty. I can see some of your other albums, but it says that one is empty.
The main album is empty it is in the sub folders by subject.
| ItalianNinja86 wrote: | Hey Rich since you stated this is only a first draft I was wondering if you
draft |
Yes I will be doing that...
OK I can see some typos myself…will try to fix them later.
Is this format OK?? Pictures with text and tips work?
Can everyone see the sub folder/albums??
I will put some pictures of the new model built in the main album when I finish a couple.
I tried to share a few tips and tricks.
And I will be adding more pictures and info ASAP.
Posted: Wed Feb 24, 2010 12:51 pm Post subject: |
| racprops wrote: | | andy wrote: | Actually Rich, that album is empty. I can see some of your other albums, but it says that one is empty.
Rich |
Here is the main album with all the folders then...
http://s922.photobucket.com/home/racprops/allalbums
