Valis Community Member
Posted: Sun Apr 11, 2010 2:34 pm Post subject: Sidkit lubrication |
| Just wondering, those of you that have built a Sidkit, have you lubricated the moving parts whilst assembling? |
propsjonnyb Community Member
Posted: Mon Apr 12, 2010 3:54 am Post subject: |
| I've built several so far, and the best method is to lubricate it after completion, as you would a 'real' gun , and use a 'silicon' based oil rather than 'gun oil or grease' as that will ensure no real wear on any of the pewter components , a little drop of oil applied to all the moving parts ( joints) will keep things in working order . If you are just displaying your blaster, a little oil every couple of months will keep it in good condition , along with a wipe over with a damp cotton cloth , will keep it pristine looking. |
Posted: Mon Apr 12, 2010 3:24 pm Post subject: |
| propsjonnyb wrote: | | I've built several so far, and the best method is to lubricate it after completion, as you would a 'real' gun , and use a 'silicon' based oil rather than 'gun oil or grease' as that will ensure no real wear on any of the pewter components , a little drop of oil applied to all the moving parts ( joints) will keep things in working order . If you are just displaying your blaster, a little oil every couple of months will keep it in good condition , along with a wipe over with a damp cotton cloth , will keep it pristine looking. |
Thanks for all the advise, thought it might need a bit. |
