jameth Community Member
Posted: Sat Jun 18, 2011 1:48 pm Post subject: Braun alarm clock question |
Anyone got a model number and or good screen caps.
Thanks |
Posted: Sat Jun 18, 2011 2:55 pm Post subject: |
Sweet. Thanks |
Posted: Sat Jun 18, 2011 3:03 pm Post subject: |
Thanks again Andy. I had seen that thread a while back and forgotten about it.
Tom |
Posted: Sat Jun 18, 2011 3:07 pm Post subject: |
Everything on Ebay has AB1A. Anyone know what the A is for? |
Posted: Sat Jun 18, 2011 3:25 pm Post subject: |
I have a couple of the AB1A's...the AB1 seems to be harder to find, but common enough in the movie . Supposedly they were being made again, but I may be wrong.
Posted: Sat Jun 18, 2011 3:34 pm Post subject: |
It turns out I have AB1's, and they are not the ones used in the film. I know Nickdarring was the expert on these. Let me double check some stuff online and see if I can for sure tell which one was used. It does seem like multiple ones were used though, but one was used more than all the others.
Posted: Sat Jun 18, 2011 3:39 pm Post subject: |
According to Nick it looks like it might be a Braun AG, type 4 821...
http://www.therpf.com/f9/blade-runner-web-props-original-pics-updated-507/
Ceck out the rest of his thread. Nick's research is the may be the the best, first of it's kind, and is certainly the foundation of everything we do here now. Thanks go out to him for setting me on my path here.
Posted: Sat Jun 18, 2011 5:28 pm Post subject: |
andy wrote: | According to Nick it looks like it might be a Braun AG, type 4 821...
If you look on his pic of the Esper the two Braun clocks are different.
Nevermind. I guess it just has a top part that is the off switch and it's up on the top one and down on the bottom one. |
Posted: Mon Jul 18, 2011 12:07 am Post subject: |
jameth wrote: | andy wrote: | According to Nick it looks like it might be a Braun AG, type 4 821...
Nope I was right to begin with. They are different. The lower one is wider. Just watched the scene. |
Vader Community Member
Posted: Mon Jul 18, 2011 2:28 am Post subject: |
jameth wrote: | Nope I was right to begin with. They are different. The lower one is wider. Just watched the scene. |
They are. This is very clear in the images in Nicks initial post in the RPF thread Andy linked to. It's even evident in the preliminary sketch Nick put at the bottom of that post. _________________ 26354 |
Posted: Mon Jul 18, 2011 7:16 am Post subject: |
I did my own research on the Esper (trying to finalize it all has been an ordeal...specially the "T.V." part ) Jameth and Nick are right: two different clocks were used. |
Posted: Mon Jul 18, 2011 11:06 am Post subject: |
Even if you can never know for sure the other model you can find a Braun that would look just like the film. I'm not sure how they determined the model of the other one. The size is right but I can't see any indication of the markings on it. Maybe they covered them up??
The problem, as in I don't want to build it, is the TV. But I think is was built from a TV and not a complete set used. Have not found anything that even looks close. I guess just use the flash to determine the size of the screen. Get a TV and remove it from it's box, build a custom box and there you go. |
Posted: Mon Jul 18, 2011 12:07 pm Post subject: |
I don't think it was a standard TV. The screen part with bezel looks to be the same one used in the spinner, and in the simple version of the Esper, just rotated. We might just be looking for just a monitor as a found part here.
Posted: Tue Jul 19, 2011 4:19 pm Post subject: |
I am pretty sure by the size of the "Cassette" insert door, it is less than 6" wide, and would be the same size as a typical car stereo.
Other things from that era, I have been looking at are of course the CED and Laser video disc players, Laminators, dot matrix printers, Paste-up waxers for Graphic design comps...and the list goes on.
Posted: Thu Jul 21, 2011 10:04 pm Post subject: |
In Nicks thread he does not say that he thinks both are the 4821 and he puts the pic of the found 4821 next to the pic of the Esper. It's the top one. So not sure If Nick meant he thought both were or not. I think he was saying he had discovered only the model for the top one.
Regardless the bottom one is not a 4821. It's wider.
Any ideas?????? |
Posted: Thu Jul 21, 2011 10:07 pm Post subject: |
Most Brauns have equal space on either side between the clock face and the edge. The bottom Esper Braun has more space on the right than the left. |
