Crowley Community Member
Joined: 28 Nov 2008 Posts: 45 Location: Suomi, ulkomaanpellet!
darthwolf7 Community Member
Posted: Thu Aug 08, 2013 10:56 am Post subject: |
| Yeah, I've seen these before. They are VERY cheaply made and molded I believe out of one piece with very few moving parts. I recommend that if you want a BR gun you save up some cash and go the Off World route...I purchased on of their blasters and have modified it to look almost like the original prop...there are a lot of options out there but bang for hour buck the best option under $600 is the Off World in my opinion...just my two cents! Thanks for showing us the blaster....cheers! |
Posted: Fri Aug 09, 2013 7:49 am Post subject: |
| Yeah, I have one of those myself already, and plan to do a fair bit of modification on it to get it looking closer to the real thing. Unfortunately I do not have an extra few hundred lying around that I could spend on a proper replica. If I did, I'd do my darnedest to find an airsoft version of the Hartford blaster. |
Posted: Fri Aug 09, 2013 10:35 am Post subject: |
| The Hartford blastrds come up on EBay every once in a. While..last one I saw went for around $900.00!?! Its also based on the wrong gun completely using a .357 base instead of s Charter Arms Bulldog...none the less a very cool pieces yo acquire for sure! Enjoy the blaster hunt mind has been a lot of fun...cheers! |
Posted: Fri Aug 09, 2013 7:10 pm Post subject: |
Our own member Baron Von Blondie is a specialist at transforming these into something quite decent...do a search and see the transformations he has accomplished  |
Posted: Wed Aug 14, 2013 10:36 am Post subject: |
| darthwolf7 wrote: | | The Hartford blastrds come up on EBay every once in a. While..last one I saw went for around $900.00!?! Its also based on the wrong gun completely using a .357 base instead of s Charter Arms Bulldog...none the less a very cool pieces yo acquire for sure! Enjoy the blaster hunt mind has been a lot of fun...cheers! |
Who knows, maybe I'll get a more common version and try to fit a separate airsoft revolver into it.
| joberg wrote: | Our own member Baron Von Blondie is a specialist at transforming these into something quite decent...do a search and see the transformations he has accomplished  |
Yeah, I have read his blog about his work on this. |
