Classic Battlestar Galatica Blaster by Racprops/Richard Coyl
PostPosted: Sun May 04, 2014 12:10 pm    Post subject: Classic Battlestar Galatica Blaster by Racprops/Richard Coyl Reply with quote
This is a REAL BLAST from the PAST:
A classic model from a classic show.
I have not made these for over 10 years and I only have a couple to offer at this time.
This model was molded from an off the studio model, which means it has all the details and FLAWs of a real on set prop.
This is as close to the real show prop you can get.
At the same time I have made a couple of improvements, this model has a bright single shot bright burst of light in its hand painted tip AND it also have the digital playback of shows blaster firing sound effect.
The sound is released by a very well hidden sound outlet, no grills or holes were added to the model or more exactly nothing was ruined or taken away to get the sound out.
This is a trick I am very proud of and has been a feature I have received praise for creating, starting with my models of Classic Phasers followed by my model of the Forbidden Planet DR Pistol, and other models.
To get the bright flashing light this model still uses an incandescent lamp to get light in all parts of the tip, it is easily replaced by a removable front tip.
And the battery is also hidden in the handle with a single hidden screw to open and replace the 9 volt battery.
See it bid on it at: http://www.ebay.com/itm/191158503618?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Thanks for looking.
