Posted: Thu Aug 04, 2016 10:30 am Post subject: NEW Coyle kit build |
Finally I got one of these! The final frontier!
Been thinking about this kit on-off for the last couple of years, wondering: do I have the skills needed to build one of these?
I will never know if I never try!!!!!
Updates (and cries for help, general frustration, panic, times of joy etc.) will follow!
I'm aiming for the "as delivered to the production" look.
Here it is, neat and ready to go on the project tray...
_________________ Monsieur, azonnal kövessen engem bitte
QuartZ Community Member
Posted: Thu Aug 04, 2016 11:01 am Post subject: |
Ahh, so this is the build you mentioned over in my thread. Cool to see the very beginning of your journey all laid out. Best of luck to you!
-Dana |
Posted: Thu Aug 04, 2016 12:07 pm Post subject: |
QuartZ wrote: | Ahh, so this is the build you mentioned over in my thread. Cool to see the very beginning of your journey all laid out. Best of luck to you!
-Dana |
That it is Thank you! I build a Sid-kit earlier this year also... _________________ Monsieur, azonnal kövessen engem bitte |
veektohr Community Member
Posted: Thu Aug 04, 2016 4:01 pm Post subject: |
I wish I had just bit the bullet and gotten in on this past run. I was just totally squeezed dry then : /
I'm gonna live vicariously through your build |
Kokanee Community Member
Posted: Thu Aug 04, 2016 6:42 pm Post subject: |
I just finished building a Coyle kit, absolutely a great time and you're left with a very high quality replica. |
Posted: Fri Aug 05, 2016 8:38 am Post subject: |
veektohr wrote: | I wish I had just bit the bullet and gotten in on this past run. I was just totally squeezed dry then : /
Hahaha
Try shooting Rich an email, maybe he can do something for you? Thing is they sell out in no time, when there's a run.... and I can understand why! _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Fri Aug 05, 2016 8:39 am Post subject: |
Kokanee wrote: | I just finished building a Coyle kit, absolutely a great time and you're left with a very high quality replica. |
Indeed. I have one that Rich build for me, it's a beast! _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Fri Aug 05, 2016 2:29 pm Post subject: |
I would recommend dry graphite spray to get the correct patina finish on the metal components, if you are going for a screen accurate worn look. Worked great on mine. |
Posted: Fri Aug 05, 2016 2:35 pm Post subject: |
Kokanee wrote: | I would recommend dry graphite spray to get the correct patina finish on the metal components, if you are going for a screen accurate worn look. Worked great on mine. |
Never heard of that product, very interesting. Can you post a link to it? _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Fri Aug 05, 2016 9:06 pm Post subject: |
https://www.amazon.com/CRC-Graphite-Lube-Aerosol-Black/dp/B007I9XUD0
Any hardware store should have it.
I am waiting on my blaster to arrive in the mail (finished it on vacation, shipped it back to avoid airline issues/theft). When it does I will post up here for you to see. Maybe you'll like it,maybe not. |
Posted: Sat Aug 06, 2016 4:27 am Post subject: |
Thanks for the link! Will it darken the metal?
Would love to see your blaster!
Kokanee wrote: | https://www.amazon.com/CRC-Graphite-Lube-Aerosol-Black/dp/B007I9XUD0
Robotprops Community Member
Posted: Sun Aug 07, 2016 2:12 am Post subject: |
I'm looking forward to see your progress.
I have a Coyle that I've yet to work on myself.
Some of the castings are a little more pitted than I might expect, but your build will show how they smooth out. |
Posted: Sun Aug 07, 2016 7:24 am Post subject: |
Robotprops wrote: | I'm looking forward to see your progress.
Contact me at racprops@cox.net and tell me when you got your kit and send pictures of the problems.
Depending on where and how bad the pitting is I may swap them out for better parts.
NOTE Any part that will be painted black, I feel can be fixed easily with bondo, and fine fillers.
And other parts can 90% of the time be sanded out.
Posted: Sun Aug 07, 2016 7:31 am Post subject: |
Good luck with your build Anders. Eagerly waiting for the first pics! |
Posted: Sun Aug 07, 2016 7:43 am Post subject: |
joberg wrote: | Good luck with your build Anders. Eagerly waiting for the first pics! |
Thanks, Joberg! Will post updates as the build progresses _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Sun Aug 07, 2016 2:43 pm Post subject: |
racprops wrote: | Robotprops wrote: | I'm looking forward to see your progress.
Rich |
Thanks Rich!
Will do. It's mostly the receiver that concerns me. |
Posted: Sun Aug 07, 2016 3:05 pm Post subject: |
They are the hardest to cast.
And the do take a lot of sanding to clean up.
IF your unable to get a fair clean up let me know.
I will work to do a exchange or can solder in the spots if needed.
OR if you able to do some I can mail you some pieces of the same metal for soldering up some of the flaws.
You will need some flux as well. I cannot send that.
But if your able to solder than you will know that and have some on hand.
Posted: Sun Aug 07, 2016 3:57 pm Post subject: |
Buch wrote: | Thanks for the link! Will it darken the metal?
Yes it leaves a darkness to the metal that looks like worn down bluing. I'll have my blaster on Monday will post up then. |
Posted: Mon Aug 08, 2016 7:46 pm Post subject: |
So the above is the results with dry graphite spray and wearing down with steel wool. |
Posted: Mon Aug 08, 2016 11:43 pm Post subject: |
Looking good, I have never used the Graphite spray but it looks like it does a great job.
The only thing I would do differently is I wouldn't use the steel wool because it scratches the finish. I would apply the graphite and then use a leather strap to rub off the metal at the edges - similar to real wear and tear.
Keep up the great work. _________________
