Goldberg Arms' .38 Cal. Detective Special revisited
Jens2133
PostPosted: Sat May 29, 2021 10:37 am    Post subject: Goldberg Arms' .38 Cal. Detective Special revisited Reply with quote
Hello, all!
As the rest of you, I have always been fascinated with Dave Goldberg's variations of our favourite blaster.
As I had a pair of grips lying around which were a tad on the small side, I decided to have a go at the idea of a .38 version of the gun.
I simply rounded off the lower back of the grips and polished them back to an acceptable sheen, using furniture polish I had at hand.
So, I guesstimated how much smaller that version would be in comparison to the real thing, and I settled at 80%. A friend printed the parts of the original blaster (the amazing version by Anders Pedersen on Thingiverse) in dark grey and black ABS and I began to put it together. I decided to use glue, since, for one thing, it will only be intended for display, and, secondly, I'm better accustomed to it.
As you can see, I am currently building an outer grip frame from styrene, on which I will then screw the grips.
Also, I felt that the 80 % Steyr mag looks a bit small, so I asked my friend to print another one at 90 % size. The original size mag is just there for comparison.
Naturally, I will update with new pictures as the build goes along.
Cheers
Jens
PostPosted: Mon May 31, 2021 11:43 am    Post subject: Reply with quote
Interesting variation on that DaveG project. Eager to see your next update Wink
Silverside
PostPosted: Mon May 31, 2021 3:09 pm    Post subject: Reply with quote
Loving the shape of those grips!
Jens2133
PostPosted: Wed Jun 02, 2021 6:12 am    Post subject: Reply with quote
Thank you!
I'll be getting the new Steyr mag next week. Until then, I'm working on the grips and other details. Hopefully I can post some pictures tomorrow.
Jens2133
PostPosted: Fri Jun 04, 2021 9:32 am    Post subject: Reply with quote
A short update. I've worked on the grip frame (I'll be leaving it closed).
Naturally, it went a tad less easy than I had hoped.
Luckily, working with the ABS will later help me hide the crimes.
PostPosted: Mon Jun 07, 2021 9:19 am    Post subject: Reply with quote
Getting there and as you said: ABS is pretty forgiving Wink
Jens2133
PostPosted: Tue Jun 15, 2021 7:19 am    Post subject: Reply with quote
Time for some updating. I've done the frame and added the new Steyr part:
It actually looks quite decent with the grips screwed on...
...and not at all as puny as I had feared:
A size comparison with the version I bought years ago on Etsy:
Still a lot of filling and sanding to do, as well as adding the sight rod (non-wired), as well as holding magnets, LEDs and a battery to the Steyr mag. And painting and a bit of weathering, of course. When it is finished, it will end up here:
More pics to come. Thanks for watching so far!
PostPosted: Fri Jun 25, 2021 9:26 am    Post subject: Reply with quote
F.A.B. work on that gun Cool It's an "in-between" DaveG's and the regular weapon...I like a lot!!
