Dann Community Member
Posted: Thu May 22, 2008 2:26 pm Post subject: |
Well it depends on how thick the metal is in the area you'd be dremeling.
I can't believe I never noticed that either! It actually looks a little different in other pics.
Looking at it more closely, the back end of that side cover looks slightly misshapen as well. |
IGNITERS Community Member
Posted: Thu May 22, 2008 3:18 pm Post subject: |
the barrel could be a bit longer and... cant see if its thicker than your last issue I know that the barrel was thinner than the prop
but YES! GREAT WORK! _________________ I've seen things ....you people appear to be intrested in ... |
EnglishArcher
Posted: Thu May 22, 2008 3:20 pm Post subject: |
What can I say? It's an astonishing piece of work by Siderio.
Some bits I'd want to modify, though:
The rear Steyr mounting
The profile and proportions of the right-hand cylinder cover
The lower flange of the RH cylinder cover (more square on the actual prop)
The position of the trigger guard, where it meets the grip frame
The shape (particularly the front curve) of the trigger guard
The rear corners of the Steyr magazine housing (too square; no holes)
The depth of the Steyr front insert
The chamfer of the barrel
The position, size and depth of the front Steyr mounting screws
It would be lovely to see the magazine components in black resin, too, rather than metal.
As I've said, though: that's just my preference; in no way is that a criticism of Siderio's work and all the effort he's put into it.
This kit is so tantalisingly, achingly close to perfection! Having seen the extraordinary quality of Siderio's work I'm sure he could achieve it should he choose. |
Finbladerunner Community Member
Posted: Thu May 22, 2008 3:56 pm Post subject: |
Absolutely fantastic work! Can't wait till this is available! |
docatomic Community Member
Posted: Thu May 22, 2008 5:12 pm Post subject: |
| Wow. Looks great! I definitely can't wait to get one... |
4yearlifespan Community Member
Posted: Thu May 22, 2008 5:38 pm Post subject: |
Great work Siderio.
simple question - is the stamped number a touch too large in comparison to the world con? Is it just the angle or weathering on the world con that makes it look smaller?
Regardless - This is very impressive.
Posted: Thu May 22, 2008 7:37 pm Post subject: |
I don't mean to pile-on here, but the thing that struck me initially was the buttplate... how thin it is in front (the little bit that sticks out under your pinky) on the Sidkit but how THICK it is on the prop.
I think the cutaway on the buttplate is perhaps cut something like this
Last edited by phase pistol on Fri May 23, 2008 1:42 am; edited 2 times in total |
Posted: Thu May 22, 2008 7:54 pm Post subject: |
I didn't get a real good shot of the "front" of the grip unfortunately, but it does seem to me that the "toe" as I call it, the little part of the buttplate that projects in front, is pretty thick... and in fact, is thicker in the MIDDLE (facing directly towards the front of the gun) than it is at the sides, if that makes sense..
Posted: Thu May 22, 2008 8:24 pm Post subject: |
Posted: Fri May 23, 2008 7:00 pm Post subject: |
| phase pistol wrote: | I don't mean to pile-on here, but the thing that struck me initially was the buttplate... how thin it is in front (the little bit that sticks out under your pinky) on the Sidkit but how THICK it is on the prop.
I think you are right on this Karl, I need to goo look through those pictures again. As if I need an excuse
BTW, I think those front two screws in the Steyr reciever are too high up and should be smaller and recessed into the reciever. The ones on the swing out part of the Cylinder cover do seem to be better, and a little more spaced out. I think the bottom one may be able to be lowered too just a bit more perhaps. The screw size also still seems a bit big, Maybe this is a difference in using metric screws. We are a stickler bunch arent we
Posted: Sun May 25, 2008 9:50 am Post subject: |
| Sid: have you thought about making the led box in plastic? I think this would be a good option as it makes the gun a little lighter and is more accurate to the worldcon. |
Nexus6 Community Member
Posted: Sun May 25, 2008 2:32 pm Post subject: |
| racprops wrote: | | I maybe wrong I forgot they pulled eyes out at his J.F.'s appartment not at the eye lab, they just placed them on Wong... |
LOLOL, OK, I'll bite. You are referring to "Chew", right? Or were you referring to the actor, who is "James HONG"? |
Posted: Mon May 26, 2008 3:20 pm Post subject: |
| Siderio wrote: | | Also the ammo clip has been made in metal because the most collectors emailed me their preferences. |
though would you still consider a plastic version as an option? some people might want a plastic one instead of metal, being more true to the worldcon prop.
Would you be able to offer some of the new kit parts seperately? as I might just convert my old kit like dan did  |
Posted: Mon May 26, 2008 8:02 pm Post subject: |
| I too would be interested in separate parts, and would love to see the mag and mag well in plastic, black plastic would be even better! |
Posted: Mon May 26, 2008 11:21 pm Post subject: |
| Dann wrote: | | I too would be interested in separate parts, and would love to see the mag and mag well in plastic, black plastic would be even better! |
Yes like I have been making for ever...
amish Community Guide
Posted: Thu May 29, 2008 7:34 am Post subject: |
Ok, I moved out some of the posts that detracted from this thread. I moved many to the Pit so that discussion can continue if people wish.
The other posts I moved are the ones where Rich talks about the price of his kits. I moved that to the Prop Shop as it would benefit him there since he is still selling the kits.
Please know, I think both men do fantastic work and I will never take that away from either of them. I just want to keep the discussion on track with what the original author intended. Hopefully nobody feel slighted. If you do, please accept my apology as I am just trying to keep things going as smoothly as possible.
Thanks!
www.bladerunnerprops.com |
drmcoy Community Member
Posted: Thu May 29, 2008 11:47 am Post subject: |
THANK YOU, AMISH.
FYI -- I am building a COYLE and a SidKit and will post a full review once I have them both done in about a month -- maybe less. _________________ teckel@bellsouth.net |
superjedi Community Member
Posted: Thu May 29, 2008 5:18 pm Post subject: |
drmcoy,
Looking forward to seeing your review. I've seen some of your Mal pistol build-up photos on RPF and they were great! _________________ I find your lack of faith disturbing. . . |
Serafino Community Member
Posted: Tue Jun 03, 2008 2:55 pm Post subject: |
| Does the grip seem a little narrow to anyone else? Also in some photos the grip angle seems a shade too vertical. Both of these effects could happen from taking the photos from too close up? |
Posted: Mon Jun 09, 2008 12:36 pm Post subject: |
Given where the shadow falls on the grip, it's actually kind of difficult to descern how narrow it is.
Maybe I just need to change my monitor settings though . . .
