Hero gun case
PostPosted: Fri May 15, 2009 3:23 am    Post subject: Hero gun case Reply with quote
Though not a prop used in the movie, the gun case that held the hero gun for possibly 25 years was also a pretty cool find to see come from the Profiles in History auction.
Here are the photos of the case from the Tomenosuke visitors...
And pictures of the case I got off of ebay...
I just received the case and may take some more pics of it soon, but it looks like it is the case by shape, color, hardware, size and texture. The only thing missing is most of the foam inserts
PostPosted: Fri May 15, 2009 3:33 am    Post subject: Reply with quote
Here is a pic of the one I got with a Coyle v3 to show the size of the case in comparison.
PostPosted: Fri May 15, 2009 3:37 am    Post subject: Re: Hero gun case Reply with quote
Not the most beautiful object Andy - especially the badly cutout foam inserts seen at the auction. But although I say that, there is unbridled fascination in the case - for me - when contemplating the reality that this iconic item hid in what looks like a shagged out Delsey hard-case for decades...
As always I'm gobsmacked at your knowledge and dedication to the franchise. Your tenacity in securing this is again credit to you, your patience and your willingness to share.
Great find and well done Sir.
PostPosted: Fri May 15, 2009 3:43 am    Post subject: Reply with quote
I have to admit, it isn't the "coolest" looking of cases. I have several that would make much more interesting props, but there is something about it.
PostPosted: Fri May 15, 2009 6:26 am    Post subject: Reply with quote
Right on Andy...always a stickler for details (and who can blame you) Cool
PostPosted: Fri May 15, 2009 7:20 am    Post subject: Reply with quote
Very nice, Andy.
Don't forget to add all sorts of dirt and rust to it Smile
chew
PostPosted: Fri May 15, 2009 8:50 am    Post subject: Reply with quote
Zero Halliburton makes a small camera case that is a perfect fit for the blaster! That's what I use. I picked it up on ebay for 50 bucks.
And speaking of poorly cut foam, does anybody know what the best way to cut out foam inserts is?
I just do eyes.
PostPosted: Fri May 15, 2009 11:39 am    Post subject: Reply with quote
They make a hot wire device that is basically wires and a battery pack on a frame that cuts foam perfectly. You can get them at hobby shops and some craft stores.
heres a bunch on ebay...
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=hot+wire+foam&_sacat=See-All-Categories
And the cheap craft store version...
http://cgi.ebay.com/HOT-WIRE-FOAM-CUTTER-wonder-cutter-stryofoam-Floracraft_W0QQitemZ230313708187QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item359fc44a9b&_trksid=p3286.m20.l1116
eltee
PostPosted: Fri May 15, 2009 12:37 pm    Post subject: Reply with quote
The instructions with the Pelican gun cases state that you should cut the outline UNDERSIZED to allow a little compression when putting in the gun as this stabilizes it. They also recommend the use of a dual reciprocating blade electric carving knife, as found in many kitchens and available inexpensively everywhere.
PostPosted: Sat May 16, 2009 3:02 pm    Post subject: Reply with quote
With the thicker foam, I found the depth of an exacto blade to be pretty much perfect, but you will have cross cut and pick out the pieces, Leaving a ragged bottom. Which I think is what you are afraid of, but it looks like what they did with the hero case.
By using three layers of foam with a thick piece top and botton, the middle section can be cut through cleanly. The kitchen knife might work fine on the higher density foam, but will tear apart the softer stuff. The hot wire is the only way I know of to make it look professionally cut down.
