megagreg Community Member
Posted: Sat Nov 14, 2009 4:12 am Post subject: |
I'm in for 1 with the correct longer length
ironfist Community Member
Posted: Sat Nov 14, 2009 9:53 am Post subject: |
I'd be down for one with the correct longer length. _________________ The other Karl! |
Posted: Sat Nov 14, 2009 10:15 am Post subject: |
ironfist wrote: | I'd be down for one with the correct longer length. |
If you have managed to get the slightly longer (more accurate) length, I'm in for one as well!
mspaw Community Member
Posted: Sat Nov 14, 2009 2:26 pm Post subject: Machined Replacement Barrel For the SidKit |
From the information I’ve gathered so far looks like 4" is the correct length. Naturally as the SidKit version is a bit over scaled ill be adding a bit on to make it appear a bit longer based on the hero prop photos. Believe me I wan it looking right for the 2 im building too
In addition the Sidkit barrel has a short tang on the back end to fit into a receiving socket in the bulldog frame. I’m adding this to provide just a bit more rigidity. For those of you that want just the flat back end I’m sure I can do a few. Naturally, Id prefer not to do too many versions but Id like to be as accommodating as possible.
Right now I’m looking at $45.00 per with an additional amount for shipping depending on if its international or here in the states. Ill post a signup list in the propshop thread as soon as I have the first 20 which should be later this week if I can make it into the shope a few nights. Ill post photos as I go along cause its fun and Id like everyone to see how its moving along.
All the best!
-Michael |
DBoz Community Member
Posted: Sun Nov 15, 2009 4:53 pm Post subject: |
I'm interested in one. I've got a Coyle in kit form that I got off of theRPF, but the mounting holes are not placed right, so I've been considering replacing it. |
Posted: Fri Nov 20, 2009 2:11 am Post subject: Machined Replacement Barrel For the SidKit |
I have the first 20 bored chamfered and cut to length. I plan on getting th mounting holes all drilled tomorrow and tapped this weekend. The front post will be early next week.
-Michael |
Posted: Sun Nov 22, 2009 10:38 am Post subject: |
count me in! |
pmafterdark
Posted: Wed Nov 25, 2009 4:20 pm Post subject: |
I agree with Staar. Great job but the barrel should be alittle bit longer as compared to the original. With this slight improvement, I'd buy one for sure. When do you think they'll be available and whats your contact info? |
Posted: Wed Nov 25, 2009 6:38 pm Post subject: Machined Replacement Barrel For the SidKit |
The girl brought home a cold and being the nice guy I am I didn’t want her to be the only one enjoying it. A cloudy head and big machinery seem like a bad combo so I haven’t done anything this week. I hope to get back to them this next week.
I just need to machine some holes and get them tapped and 20 will be good to go. I promise Ill post a signup list as soon as the first set is ready.
all the best!
-Michael |
pmafterdark
Posted: Wed Nov 25, 2009 8:47 pm Post subject: |
Thanks, thats great. I'll be sure and look for your list once its posted. Just curious, are you a machinest by trade? You do very nice looking work. |
Posted: Wed Nov 25, 2009 9:27 pm Post subject: Machined Replacement Barrel For the SidKit |
Thanks for the complement. Nope I’m a hobbyist machinist at best. My day job is visual FX for film but its ever so nice to step away from the computer and do something a bit more tangible now and again.
-Michael |
Photech Community Member
Posted: Wed Nov 25, 2009 11:48 pm Post subject: |
I'm in for 1 if it will fit the new racprop kit coming up. _________________ No! 4, 2 - 2, 4. |
Posted: Mon Nov 30, 2009 6:18 pm Post subject: Machined Replacement Barrel For the SidKit |
yep this first run is completely geared to the sidkit. Ive ordered up one of racprop kits as well and when it comes in ill build a version specificly for it.
-Michael
P.S. thinking the alum butt plate is next. |
Hasenbrau Community Member
Posted: Mon Nov 30, 2009 6:33 pm Post subject: |
Haha wow - I'd be in for a couple of butt plates too! You keep this up and you'll have your own kit on the market  |
Posted: Fri Dec 04, 2009 12:07 am Post subject: Machined Barrel for the SidKit |
So The last two days in the shop have been productive. I have 25 barrels almost ready to go. I only need to drill the 2 side machine screw holes and tap them. The The larger m6 screw hole was drilled and tapped tonight. Im pleased as all of the holes are blind, meaning unlike the SidKit barrel you will not see the screws protrude into the bore. For those of you Picking up rich's kit (I am) you may want to pick up a barrel or wait till it comes out as I may want to make slight adjustments once I see the fit. Either way its nice to have a mill on hand to do the drilling and tapping. It makes getting everything true a hell of a lot easier.
Ill post photos soon.
-Michael
P.S. The stand off posts are done as well.
neosporing Community Member
Posted: Fri Dec 04, 2009 10:29 am Post subject: |
hello,
i hadn't been here since sid's death, and hadn't realized all that was going on. This barrel looks amazing. can i get in on the run? |
Posted: Fri Dec 04, 2009 11:46 am Post subject: |
So if the sidkit's bolts are too long, they won't screw into your barrel? Or are you including those too? |
Posted: Fri Dec 04, 2009 5:32 pm Post subject: machined Barrel for the SidKit |
The cap head screws will be included.
-Michael |
pmafterdark
Posted: Fri Dec 04, 2009 5:38 pm Post subject: |
Glad to hear your making the screw holes "blind". That was another one of the things that bothered me abit with Sidkit's version, besides the incorrect barrel bore. Looking really forward to getting one when they're done! Great work Michael!  |
Posted: Sat Dec 05, 2009 7:20 am Post subject: |
Glad this is moving along. I think I will wait for a Coyle version. |
