DonParker Community Member
Posted: Fri Dec 18, 2009 4:09 pm Post subject: |
Ok guys, Ill need to do some costing on the aluminum
but it shouldnt be that much.Heres what Im thinking
with the offworld plates.Id like to go with
.5 by 1.5 6061 bar aluminum.I want it thicker so
I can put in a bigger pinky relief. I dont know how big
your hands are but mine were to big for the
offworld. Another thing is that the offworld grips are
parallel to the grip frame and the plate I made has a
taper towards the rear of the gun like the worldcon.
If I make it like the worldcon the stock grips may
look funny. Let me know what you think.
Don |
punctated Community Member
Posted: Fri Dec 18, 2009 4:33 pm Post subject: |
| The thicker plate sounds fine with me. Since the OffWorld is no Worldcom I think keeping true to the original OffWorld buttplate would be the best. |
Posted: Fri Dec 18, 2009 8:11 pm Post subject: |
I should have a plate done tomorrow.Ill
post some pics so you can see if they'll
be ok.
Don |
Posted: Fri Dec 18, 2009 9:44 pm Post subject: |
| The thicker buttplate is definitely the way to go. The OW Blaster grip is way small and my hands aren't even that big. |
Posted: Sat Dec 19, 2009 2:43 pm Post subject: |
Looks great. I will take one.
Thomas |
Posted: Sat Dec 19, 2009 2:51 pm Post subject: |
I would prefer the taper and thicker plate, but I know the rear screw is positioned too far back to have much of a taper. Still, it is the design element on the worldcon that really makes it look so much better than any of the replicas before it.
Posted: Sat Dec 19, 2009 2:52 pm Post subject: |
Thanks Thomas if you can PM me your info and payment method
I could ship asap. |
Posted: Sat Dec 19, 2009 6:30 pm Post subject: |
I guess all who want a plate should pm me their info.
Don |
Posted: Sat Dec 19, 2009 9:41 pm Post subject: |
| Can they be made with the rear taper? |
Posted: Sat Dec 19, 2009 10:02 pm Post subject: |
Hirohawa, The plate in the photo does have some taper.
I can give it some more if you would like.One of the
biggest problems with the offworld is the size of
the screws for the butt plate. If I give it to much taper
it could break into the counter sink for the socket
head screw.They're pretty big.
Don |
Posted: Sat Dec 19, 2009 10:22 pm Post subject: |
One thing I wanted to ask you Andy.Do you know of
anyone that might have drawings with dimensions
for an actual bulldog frame?The gun Im making now is
me just guessing at hole placement and dimensions.
I wouldnt mind making another frame from
aluminum but I just dont have a real bulldog to work with.
I know your the goto man around here so I thought I'd ask.
Don |
Posted: Sat Dec 19, 2009 11:12 pm Post subject: |
I will double check my CA bulldog Op manuals I have, but I am pretty sure they don't have any dimensions, just exploded views. It might be worth another google search though, or just a call to the Charter Arms company themselves.
Posted: Sun Dec 20, 2009 2:23 am Post subject: |
| I have a CA bulldog. Which dimensions do you need? |
Posted: Sun Dec 20, 2009 6:27 am Post subject: Butt plate |
Hi I'd be very interested in 2 butt plates. Pm sent with my details
mike |
neosporing Community Member
Posted: Sun Dec 20, 2009 10:19 am Post subject: sidkit worldcon buttplate? |
howdy,
i'd be interested in a tapered buttplate for the 2006 sidkit?! i don't know if your buttplate your offering was made to fit the monsters in motion 'offworld' or sidkits 'worldcon'...
But if you ever do, (or have done) a tapered 'worldcon' version that would fit onto the sidkit, i'll take one! |
Posted: Sun Dec 20, 2009 5:40 pm Post subject: |
Thanks guys. Neo if you can or anyone can give
me some dimensions of what size the sid kits plates are
and where the mounting hole are Id be happy to make one for you.I dont have
a Sidkit to go off of unfortunately Sid passed
away before I could get one. Let me know what
you want and Ill do my best to make it for you.
Don |
Posted: Sun Dec 20, 2009 10:21 pm Post subject: |
woohooo! exceedingly kind of you sir! i'm not exactly sure how to get you the measurements you are asking for. I have a 2006 sid kit with an 'inaccurate' (non tapered butt-plate) I'm hoping someone with an 'accurate' worldcon butt-plate will step up to this plate and provide the info you seek... for the greater good of course
i dunno, should i stick the 06 sidkit bulldog frame on a xerox machine? would that work? |
Posted: Mon Dec 21, 2009 2:20 am Post subject: |
Neo maybe you could take the plate off
and copy that on both sides making
sure that it is 1:1 scale.Then Ill give you
my private email and you can just sent it
to me.
Don |
Posted: Mon Dec 21, 2009 12:36 pm Post subject: |
| pm sent |
