Posted: Fri Jan 29, 2010 2:15 pm Post subject: |
I'll get another Contempra soon and start a Vid-Phone but with the red light on top of the view screen...when I have the time of course  |
Posted: Fri Jan 29, 2010 8:01 pm Post subject: |
Here you go J, i know your all about detail.
Sorry Andy, at least its a small victory against our SW cousins.
Posted: Sat Jan 30, 2010 9:06 am Post subject: |
Thanks Tim, makes more sense now; less work for the next one  |
Posted: Sat Jan 30, 2010 2:30 pm Post subject: |
Yes, I am glad one of us got it.
Wesclone Community Member
Joined: 24 Sep 2008 Posts: 12 Location: San Antonio, TX
Posted: Sat Jan 30, 2010 5:09 pm Post subject: |
I've found the phone. The calc is a toughie. However, I've found several slide viewers, but I can't tell which one is the correct one. Can some one post a picture, "pre-mod"? Did it have a base, or a side attachment? Also, for those with a full calculator, what are the odds of getting casting?
Wes |
Posted: Sat Jan 30, 2010 11:04 pm Post subject: |
I am not 100% sure of the accurate slide viewer, or if it is even a slide viewer for sure. The Panaview 2 1950's style is the closest thing I have found.
Posted: Sun Jan 31, 2010 5:11 pm Post subject: |
| I choosed the Kaiser slide viewer because it was basically a rectangle box with straight sides. The only thing I'm concerned about the Panaview is that the design is a trapeze. So the side are getting narrower toward the rear of the screen, making the overall look of the Vid-Phone (and looking at the screen/pics captures of Leon's interview) different than in the movie. As for a mold of an original MQ-11 it would be difficult, but not impossible. |
Posted: Tue Feb 02, 2010 2:23 pm Post subject: |
I saw a tutorial on the RPF showing how to do a step by step motion tracker used in Aliens. The slide viewer was made by Hama...looks like it could be used for the Vid-Phone also...or a another type of Vid-Phone  |
Posted: Tue Feb 02, 2010 2:55 pm Post subject: |
| joberg wrote: | | ...or a another type of Vid-Phone |
...or another great project on the bench in the near future, joberg ?
Posted: Wed Feb 03, 2010 7:16 am Post subject: |
Yes Fred, in the near future...if I can convince the GF that I need another Vid-Phone  |
Posted: Wed Feb 03, 2010 7:58 am Post subject: |
You can never have too many Vid-Phones  |
Posted: Wed Feb 03, 2010 10:12 am Post subject: |
You're right Neil; this time I'll put the red light and some tastefull greeblies/wiggets on top of the slide viewer  |
Posted: Wed Feb 03, 2010 5:19 pm Post subject: |
| joberg wrote: | You're right Neil; this time I'll put the red light and some tastefull greeblies/wiggets on top of the slide viewer  |
Hmm... Dear joberg, try to think of a better argument to convince your wife of your absolute NEED for another Vid-Phon ! (good luck, mon pote !!!)
Posted: Thu Feb 04, 2010 7:17 am Post subject: |
Merci Fred, je vais en avoir besoin (thanks Fred, I'm going to need it)  |
Posted: Thu Feb 04, 2010 7:35 am Post subject: |
You could always say that having 1 phone is pointless, no one to ring  |
jameth Community Member
Posted: Thu Feb 11, 2010 11:46 pm Post subject: |
What kind of and thickness of plastic did you use to expand the base of your vid phone??
| joberg wrote: | Well, well, well, to answer that question, here's my new project...again, not accurate, but close enough; now if I can convince my GF to part with the tube of her hairdryer (should not be long now ) I'll have a complete Vid-Phone. Still work to do...
[url]
[/url]
[url]
[/url] |
Posted: Fri Feb 12, 2010 7:16 am Post subject: |
| I used a 0.2mm thick plastic; it's easy then to sand the edge to a nice round form. |
Posted: Fri Feb 12, 2010 1:33 pm Post subject: |
What kind of plastic?
ABS seems hard to work with. Is it PVC?? | joberg wrote: | | I used a 0.2mm thick plastic; it's easy then to sand the edge to a nice round form. |
Posted: Fri Feb 12, 2010 2:20 pm Post subject: |
Sorry Jameth, I usually use Syntra or Plasti-Card or Evergreen, these are the trade-marks. Your hobby store will help you with your selection.
I use contact cement with all my work, also a good glue gun is a must.
Good find on the Kaiser . Don't forget, if you use a Kaiser, you'll have to find/scratch-build the calculator. |
