		| Author | Message |
		| racprops Community Member
				|  Posted: Thu Apr 08, 2010 9:41 am    Post subject: |   |
				| That maybe true for normal pewter.
 I use an alloy that is 98% TIN, and I machine the barrels on a lathe and other parts.
 They come out great.
 IF you feel the tap may cut too deeply, just start it in a little and back out.
 And I put these models together and take them apart a lot, test fitting and blending parts with no notable problems with any threads.
 I really worked hard to find a good metal, yes it can have some minor pits, but 89 to 98% of these clean out, and if you do get a part that you cannot clean up, nor live with I will either fix it for you or replace it.
		| Back to top |  |
		| Author | Message |
		| andy Community Guide
				|  Posted: Thu Apr 08, 2010 10:26 am    Post subject: |   |
				|  	  | marsattack wrote: |  	  | If I may add, pewter is made up of a combination of alloy ,zinc and antimony . Very soft and unturnable, only good for casting. Screws will more than likely cross thread prior to tightening.
 I found that if  the holes are drilled correctly , the actual screw may be used for tapping the hole as the tap may loosen the thread.
 Try not to screw and unscrew these screws, test fit and leave it alone.
 Also noticed that super glue or cyanoacrylate based glues will fuse this material , so if cross threading occurs dot the screw with super glue prior to screwing......however this will secure the screw in place, making it harder to remove later on.
 Hope this helps and great help thread BTW
 Marcel
 Actually from what I have learned, most pewters are 85% - 95% tin. Other metals and such are added to keep it from disintigrating into a powder including  copper, antimony, bismuth and lead. Antimony isn't even really a metal and also expands as it cools. It is used now to replace lead in most solders and pewters. Zinc was often called "spelter", which "pewter" may be a derivation of.
		| Back to top |  |
		| Author | Message |
		| propsjonnyb Community Member
				|  Posted: Thu Apr 08, 2010 2:49 pm    Post subject: |   |
				| If you  really  want  to  be accurate  copper is the  next percentage wise and  that's  the metal  that  reacts best to  the  oxidation process  when  applying  'Pewter Black'  or any other  antiqueing product , most are  toxic so  use  protection  gloves, mask and eyes -  always  follow  the  instructions and have copious amounts of water  available.  I coat my pieces  in layers letting each coat  react  and  repeating the  washing  drying  coating  process until I build up the  level  of 'blackness'  I want ,  I say 'blackness'  but since  Rich 's alloy  has a good copper content  the first coat  always goes  coppery then  starts to  darken with each subsequent coat , once you've reached the  desired level ,  wash & degrease the  piece  and allow to  dry  completely, before  sealing the finish  ,  I use a wash of  five  parts  white spirit, to  two parts  dark brown and one part  black  acyrillic,  mixed and  washed over the  piece , wipe off with a cotton cloth  or  rag any excess ,  the  stain  sets in the  crevices  as the  white  spirit evaporates giving an aged weathered appearance and effectively  'seals' the  piece from further  darkening. |  |
		| Back to top |  |
		| Author | Message |
		| marsattack Community Member
				|  Posted: Thu Apr 08, 2010 5:05 pm    Post subject: |   |
				| well there you go then! i should haved googled it and read WIKIPEDIA
		| Back to top |  |
		| Author | Message |
		| jameth Community Member
				|  Posted: Thu Apr 08, 2010 5:11 pm    Post subject: |   |
				| What about just painting the pieces.  The Hero prop looks like it has a gun metal finish on it.
 Would Gun Metal spray paint work????
		| Back to top |  |
		| Author | Message |
				|  Posted: Thu Apr 08, 2010 5:15 pm    Post subject: |   |
				| It should, any paint will work.
 I do paint the black parts. And with paint you can use fillers and bondo and primer to get a near perfict finish.
 It just is there is no paint that will give the textured look of real stained metal.
 So the parts that was raw steel I try to treat them with a blacking agent that gives pewter which looks too sliver a more steel look.
		| Back to top |  |
		| Author | Message |
				|  Posted: Thu Apr 08, 2010 5:43 pm    Post subject: |   |
				|  	  | marsattack wrote: |  	  | well there you go then! i should haved googled it and read WIKIPEDIA
		| Back to top |  |
		| Author | Message |
				|  Posted: Fri Apr 09, 2010 4:44 am    Post subject: |   |
				| The trick is of  course 'weathering' the  pewter black afterwards ,  I think I've tried every and all combinations listed on this forum at one time or another   and  I've built a lot of  blasters,  not so many as Rich but  more than most . All  are considered good  effects  -  it s a matter  of personal taste which one you choose,  but ultimately it depends on the effect  you want to achieve . You  can  spray with  a gunmetal metalcoat , but you must use an airbrush set on a finemist spray , then a very soft polish  to burnish  the finish  and then a final coat of clear lacquer
 The lead pencil graphite rub is a good one, followed closely by the  black boot polish , but  I would then seal the graphite with a blast of spray mount and let it  dry completely, before using the polish sparingly .
		| Back to top |  |
		| Author | Message |
		| Michael Community Member
				|  Posted: Fri Apr 09, 2010 7:49 pm    Post subject: Newbe |   |
				| Ok, Got my kit this week, and I'm completely new at this.  I've got hands on experience with wood, painting and drawing, so I'm not completely intimidated by this.  I also have access to a machine shop, they make everything from folding chairs to high precision parts for gov contractors, so I'm sure they have everything I'd need.
 While the parts in the kit itself are a little rough, its way better than I thought it would be, given some of the warnings in the propshop thread.
 I'd like to screw up as little as possible, although I'm sure I'll so something stupid at some point in the process.
 Any of the serious work i can do at the shop, but I also don't want to impose on my friend too much.  So much of the work I'd like to do at home by hand.
 What's a good basic set of tools I would need to do a good job?
 From propsjohnnyb's post I figure a pin vice
 What bits and tap sizes would I need?
 What range of sand paper?
 What kind of polishing compound?
 Any other advise
 Thanks,
 Michael
		| Back to top |  |
		| Author | Message |
				|  Posted: Fri Apr 09, 2010 7:56 pm    Post subject: Another Newbe questions |   |
				| Ok, Another newbe question
 I'm trying to get a sense of the order I should approach the various tasks,
 This is my question
 1 Sand (all parts, apply filler to the painted parts)
 2 Polish
 3 Drill and tap
 4 test fit
 5 modify parts
 6 test fit
 repeat 5 and 6 as necessary
 7 final finish
 8 final assembly
 I know its wont be that cut and dry, but I'm looking for the general order of things
 For instance I'm not sure when I should drill and tap, I could also see that happening between the sand and polish steps
 Thanks
		| Back to top |  |
		| Author | Message |
				|  Posted: Fri Apr 09, 2010 9:07 pm    Post subject: |   |
				| 1 Sand Yes, mainly remove flash.
 2 Drill and tap yes
 3 test fit  yes
 4 modify parts if needed yes
 5 Do all of the major sandings now, apply filler to the painted parts.
 6 test fit  yes
 repeat 3,4,5 and 6 as necessary
 7 final finish Paint
 8  Polish now
 9 Metal finish
 10  final assembly
 I would drill and tap first, that way if you slip and did a part, or break off a drill or tap, it will not with hours and hours of work in the part.
 I would drill and tap first, that way if you slip and divot a part, or break off a drill or tap, it will not have hours and hours of work in the part.
		| Back to top |  |
		| Author | Message |
		| steevy Community Member
				|  Posted: Fri Apr 09, 2010 9:45 pm    Post subject: |   |
				| I'm anxious to see what some of the builds come out like.Some guys on this site do great builds. |  |
		| Back to top |  |
		| Author | Message |
				|  Posted: Sat Apr 10, 2010 8:23 am    Post subject: |   |
				| I would agree generally  with Rich ,  it nice  to  have a shop with all the tools  to hand  but  you  don't  need many , a set of  riffer files,  screwdrivers , access to a drill,  a sander , allen keys  ( supplied with the  kit ) a soldering  iron, a table  vice  and a few  handyman tools will suffice.    The  drill bits and taps  needed,  Rich has  listed on his photoalbum  which  shows all stages of  a build up  and is a very  good example to  follow . You  want a bottle of  degreasser ( white spirit , acetone are two good examples  or  a degreasing  agent  from any  good  motor accessory shop)  copioius amounts of water  , protective  gloves  dust masks and eye protection  is an absolute - Must Have!!    A bottle  of  'Pewter Black'  available via internet , mail order or  any  good  hobby shop )  A tin of  automotive  spray primer and  a tin  of  matt black paint.
 I was and am continuing to  give a working  brief and suggestions ,  as  we go through the build stages here, it not a full tutorial  but it  will explain some of the  professional  tricks  we use to  create a successful replica of a  film prop  and since we are  building using  an accurately created cast kit  by  Rich  we are  going to  have  some of the  best blasters ever when  we finish !
 I would  certainly  prep and clean all the  flash  first ,  then  first  pass,  sand all the  parts  smooth , then drill  and tap each piece in turn ,  then  sand to  polish stage -  that 's putting  a mirror  finish on all parts  with   240/440 grit  -   I tend to  use  the  belt sander  for  most straight  flat surfaces  the  free belt for  curved pieces , then  sanding  block's
 (various  grades C,M,F, VF) and  sanding sheets,  again  say course  180, medium  200/220, and fine  240 . When  drilling and tapping ensure  you  clean  and deburr the  holes as  you  go.
 Then onto  polishing , I prefer to  use  proper  polishing  compounds  which can be  bought  at  most  metalwork , hobbyshops or  biker  build shops, using  a bench  grinder  fitted with polishing  mops -    but  you  can  buy  car auto polish in kits that are  equally as good just follow the instructions.   I like to  start  with  grey or  brown as a first pass, set  the  grinder going  ,  hold the  bar of compound against the  spinning wheel for  2 seconds to charge it  and then  using  protective  gloves give the  piece a good polish  -   then  Green or Yellow on another mop, finishing off with  Pink or  Blue on a soft  cotton mop  , the  different  compounds contain different  types of  grit and also  give  a factor of  polish finish  9 being the  highest   ( Pink or  Blue)
 Vienna Lime Powder ( Yes it does get technical!  -  actually it is  very, very  fine  chalk powder  ) it's  used on a cloth as a final  clean up  to  remove  and  grease marks - don't use too much polish as it'll leave grease streaks on you  piece  - a sure sign you've used too much compound ,  the  secret is little and often ,  I some time polish a piece  two or three times  - before  I'm happy  with it . If you  haven't got a bench polisher  a dremmel tool  with  three different mop heads will do  the  same  job  and  if you  haven't got a dremmel  - then  a huge amount of  fine sanding by hand  - will ultimately  give you a reasonable  result.
 Then onto 'pewter blacking' all the  parts you  want to  look like a 'blued' real steel gun ) described  above already)    then metal finishing, assembly,   final weathering  and finished !!
		| Back to top |  |
		| Author | Message |
		| Back to top |  |
		| Author | Message |
				|  Posted: Sat Apr 10, 2010 9:57 am    Post subject: |   |
				| When it comes to working on a model the classic saying is measure three times cut once.
 I don’t mind the questions and answers if it saves one model even one part from being messed up.
		| Back to top |  |
		| Author | Message |
				|  Posted: Wed Apr 14, 2010 5:44 am    Post subject: |   |
				| ok  Back to  the  photos  , here' s a few shots  showing  the  current  level of  progress
 next  update    handy hints and tips!
		| Back to top |  |
		| Author | Message |
		| Gaff87 Community Member
				|  Posted: Wed Apr 14, 2010 5:54 am    Post subject: |   |
				| Great pics, Propsjonnyb.
 Neil
		| Back to top |  |
		| Author | Message |
		| joberg Community Member
				|  Posted: Wed Apr 14, 2010 6:16 am    Post subject: |   |
				| Lookin' good so far; I love it!  Thanks for sharing. |  |
		| Back to top |  |
		| Author | Message |
		| ironfist Community Member
				|  Posted: Wed Apr 14, 2010 3:16 pm    Post subject: |   |
				| Rich, I would love to see some pics of the actual casting pouring process of these parts. I think it would be cool to see there raw state!!!!
 The other Karl!
		| Back to top |  |
		| Author | Message |
		| BeastMaster Community Member
				|  Posted: Tue Apr 20, 2010 9:31 am    Post subject: |   |
				| The post at the end that connects the barrel with the LED case is white plastic  this should be a blued metal part. Are there any plans on updating this with a metal version? _________________
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
