New Coyle front trigger spring idea
jameth
PostPosted: Sun Jul 11, 2010 8:25 pm    Post subject: New Coyle front trigger spring idea Reply with quote
Here is some pics and video of the spring I used for the front trigger of my new Coyle Blaster.
I wanted to wait to take it apart until I was ready to work on finishing painting and pewter dying the gun. Obviously the blaster is not finished yet.
Video
DSC_0037.mp4 video by jameth1971 - Photobucket
DSC_0009.mp4 video by jameth1971 - Photobucket
propsjonnyb
PostPosted: Mon Jul 12, 2010 4:33 am    Post subject: Reply with quote
Nice idea ,
I 'll see if I can source some thin steel strip and try to create some springs, as you've probably found the rear trigger spring isn't so hot either, as sometimes it sticks and the trigger doesn't return as it should . So I would strongly suggest changing the rear one as well.
PostPosted: Mon Jul 12, 2010 6:21 am    Post subject: Reply with quote
Good stuff Jameth! Eager to see that new Coyle coming to life!
jameth
PostPosted: Mon Jul 12, 2010 12:04 pm    Post subject: Reply with quote
If you want to use a Swiss Army spring they can be found here.
I would suggest getting several.
http://www.oregonknifeshop.com/repairandparts.html?gclid=CNzSvaO75qICFRJDgwodmjFHxw
jameth
PostPosted: Mon Jul 12, 2010 12:07 pm    Post subject: Reply with quote
propsjonnyb wrote:
Nice idea ,
Great idea. I would not mind if the swiss spring was just a tad stronger. It's works great but is a little light. A slightly stronger steel would feel real good.
propsjonnyb
PostPosted: Tue Jul 13, 2010 5:02 am    Post subject: Reply with quote
Having watched the video, I would concur that bending the spring up at one end and drilling a small hole would be a good idea , a spot of superglue in the hole will fix the spring in place. The rear trigger already has a hole drilled in the trigger and a matching one in the gun frame , so bending both ends and fixing one end in the trigger ( superglue) and leaving the one in the frame un-glued should give fully working front and rear triggers, that will not stick and will always return .
