Voight Kampff Case!
Goto page Previous  1, 2
PostPosted: Mon Aug 16, 2010 9:56 am    Post subject: Reply with quote
I think it's still a one-off made for the film; you can see in the previous pics posted by Nick that when the case is closed all the way, there's still a gap between the two parts (at the bottom). Usually, these cases are either made with ABS plastics or if not, an aluminum lip is placed around the two parts (top/bottom) to make sure the case is tight shut.
PostPosted: Tue Aug 31, 2010 6:46 am    Post subject: Reply with quote
Bumperoo! Hope that more pics are going to be posted of the case...as well as the VK machine itself Wink
propsjonnyb
PostPosted: Tue Aug 31, 2010 7:04 am    Post subject: Reply with quote
Agree, with you , this should be the easiest conversion , I'm just going to cover the Haliburton 'a la offword66' as it'll be quik to convert and finish can anyone confirm that the top matches ( is a mirror) of the top?
PostPosted: Tue Aug 31, 2010 4:10 pm    Post subject: Reply with quote
Cannot confirm if no more pics are surfacing...unless the bottom is the same as the pic showing Deckard exiting his car in front of his apt.
hole dweller
PostPosted: Wed Sep 08, 2010 5:09 am    Post subject: Reply with quote
Hey guys
I use to work in video production and that case looks like a case for lighting equipment.
http://www.lowel.com/cases.html
The styles have changed over the years but I think and older case may be what you are looking for.
Check ebay.......
Gary
WWW.GFORCEMODELS.COM
PostPosted: Wed Sep 08, 2010 6:49 am    Post subject: Reply with quote
In BR if you hold the case normaly, the lines are horizontal...on the Lowel's they are vertical...the search continues Crying or Very sad
nickdaring
PostPosted: Fri Feb 17, 2012 1:52 pm    Post subject: Reply with quote
Stumbled across this today-
http://www.ebay.com/itm/HARRISON-FORD-BLADE-RUNNER-BEHIND-Scene-Photo-BRC-03-/150739667899?pt=LH_DefaultDomain_0&hash=item2318c8cbbb
Nick
PostPosted: Fri Feb 17, 2012 2:37 pm    Post subject: Reply with quote
Good catch Nick! Cool
nickdaring
PostPosted: Tue Apr 02, 2013 11:00 pm    Post subject: Reply with quote
Thought I'd bump this back up since there's been so much VK scholarship work going on.
PostPosted: Wed Apr 03, 2013 7:00 am    Post subject: Reply with quote
Nick, I started a V.K. case project on the next thread Wink
Page 2 of 2
