She was trained for an Off-World Kick/Murder Squad...
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 11, 12, 13  Next
Bendzhamin1967
PostPosted: Fri Aug 31, 2012 7:59 am    Post subject: Reply with quote
THAT is awesome looking!
PostPosted: Fri Aug 31, 2012 8:06 am    Post subject: Reply with quote
Culmination of many working hours into a very good lethal design!
What I like about this gun is that nothing is feminine about it: cold, efficacious and precise. "You shoot, you kill and you get out" Cool
Many thanks Rick for making us witness of the process and the result.
PostPosted: Fri Aug 31, 2012 8:22 am    Post subject: Reply with quote
I think you could issue some signed and numbered lithographs of this image!!
Fantastic.
PostPosted: Fri Aug 31, 2012 8:46 am    Post subject: DO ANDROIDS DREAM IN 3D? Reply with quote
See Rick. Told you . . . .Smile
The renderings themselves are gorgeous!
- R13
DaveG
PostPosted: Sun Sep 02, 2012 11:48 am    Post subject: Reply with quote
Outstanding! Looking forward to seeing this for real!
Dave
doppelganger01
PostPosted: Mon Sep 03, 2012 12:17 pm    Post subject: Reply with quote
Thank you. I hope it lives up to expectations.
Rick
www.pflagerkatsumata.com
www.ricklross.com
doppelganger01
PostPosted: Fri Sep 07, 2012 8:43 pm    Post subject: Reply with quote
The parts arrived today.
These photos were taken directly after removing the parts from the box, so they are in their roughest state. The white parts were printed in a Laser Sintered Nylon Plastic. These parts did not require untra high detail, so it was more economical to have the bulk of these parts printed in this manner. The translucent parts were printed in a UV cured acrylic polymer. These parts required a much higher resolution to better capture the lettering, and therefore, cost a bit more to print. All parts have "print lines" that need to be dealt with.
The next phase of the process will be the most difficult. A combination of sanding, priming, and sculpting is required in order to dial in each part. The surfaces must be void of all print lines, but great care must be taken not to sand away the fine details, primarily the lettering. This will be achieved by priming the pieces with gray primer and then applying spot putty only to those areas that need filling, followed by light sanding. In addition to removing the print lines, there are some parts that need some additive sculpting in order to properly refine their curvilinear shape. The goal is to make the parts look machined and or stamped, but not printed.
Once I have these parts primed, I'll post additional photos. They will pop in the pics and not look so washed out.
www.ricklross.com
panaflex
PostPosted: Fri Sep 07, 2012 8:50 pm    Post subject: Reply with quote
Orson Welles
PostPosted: Fri Sep 07, 2012 9:12 pm    Post subject: Reply with quote
Holy cow those are awesome.
PostPosted: Fri Sep 07, 2012 10:20 pm    Post subject: Reply with quote
gobsmacked
PostPosted: Fri Sep 07, 2012 11:26 pm    Post subject: TECHNOFANTASTIQUE! Reply with quote
AH, TECHNOLOGY! This is SO cool! I can hardly wait to see this project as it moves forward!
In a few years this process may seem rather commonplace as technology continues to advance. Recently I watched a vid on 3D Printing on the NAT GEO Channel - something NASA is considering for future missions. There are now high-end machines that will "print out" a 3-dimensional piece with working interlocking parts, in place and in different colors, the latter assigned by a simple keystroke. Amazing!
If you've not seen this, check it out:
http://www.youtube.com/watch?v=pQHnMj6dxj4
Soon you might not even need to do the cleanup - although as with all works of art like this, I think creative vision and the human touch will always be paramount.
Nice work, Rick! - R13
PostPosted: Sat Sep 08, 2012 8:06 am    Post subject: Reply with quote
Excellent Rick...btw, what's the grit you'll use for sanding those beauties?
And as Rep13 mentioned, the desk top 3-D machine are already there, albeit not as sophisticated as a $ 270.000 machine (Shapeway) but good enough for little pieces and small object.
PostPosted: Sat Sep 08, 2012 10:19 am    Post subject: Reply with quote
Very cool Rick Cool
nexusfx
PostPosted: Fri Sep 14, 2012 2:21 am    Post subject: Reply with quote
drool:drool: want drool: drool:
Bendzhamin1967
PostPosted: Fri Sep 14, 2012 7:51 pm    Post subject: Reply with quote
I see the level of intricate detail that 3D printing allows for and i can totally see the Star Trek Relicator in its infancy... Shocked
PostPosted: Mon Sep 17, 2012 3:21 am    Post subject: Reply with quote
Ditto Ditto Ditto Ditto Ditto
oldzey
PostPosted: Fri Sep 21, 2012 9:24 am    Post subject: Reply with quote
Rock and Roll, Hoochie Koo. Cool
doppelganger01
PostPosted: Tue Oct 30, 2012 12:33 am    Post subject: Reply with quote
Very soon I will have news on this long overdue project - built-ups and kits.
Rick
www.ricklross.com
PostPosted: Tue Oct 30, 2012 2:58 am    Post subject: ANTICIPATION Reply with quote
- R13
PostPosted: Tue Oct 30, 2012 7:25 am    Post subject: Reply with quote
Good news there Rick; looking forward already to member's build-up Cool
Page 6 of 13
