How should I convert a Kanamaru airsoft bulldog to a PKD
ItalianNinja86
PostPosted: Thu Feb 07, 2013 9:35 pm    Post subject: How should I convert a Kanamaru airsoft bulldog to a PKD Reply with quote
A little History before the main question I have to ask
So back in December I managed to get one of these from a member of the RPF
you can imagine my excitment in acquiring one of these. However with excitement came a fear that it might not be the right size that was relived by measuring against my Coyle Blaster
it lined up ad was a perfect size in relation to my Coyle.
Fast forward to January I decided to start making plans to convert it to a PKD (surprise surprise) and got in touch with Rich to discuss buying another kit version of his blaster after I got my tax return. fast forward a week or two and sadly Rich retired due to health problems (not complaining and I have only myself to blame for not acting sooner and I'm glad Rich is doing better).
And now for the reason I'm posting this thread.
how should I convert it if I still decide to do so?
Now I really rather not take my Coyle blaster apart and use it in the conversion process since it was put together by the man himself and is a really nice display piece as such. But as of now I only have two ideas of how to go about this and could use some input.
The member I purchased this from and this forum both mention a conversion kit that came out for this airsoft pistol.
I was wondering if anyone had any pictures of this kit or what it looked like finished?
And though it may be a long shot have any ever come up for sale?
I've seen a few sidkits up for sale recently and whiles sid's look nice I know nothing about how they measure up to the real parts.
If I decided to buy a sid do you think it would scale right?
Of course the biggest problems if I do convert it would be the barrel and grip but I have a few ideas to go on if I ever get that far in the project.
Any ideas or suggestions are appreciated. Hell I might just leave it as is cause it might be more trouble then ts worth to do what I want to do it. Then again if anyone has a kit they want to part with for a reasonable price let me know maybe we can work something out.
PostPosted: Fri Feb 08, 2013 7:45 am    Post subject: Reply with quote
As far as transforming the Coyle you already have: don't do it! Keep it as is...it's been put together by the man himself and shoudn't be touched.
Now as for a Sidkit, if my memory serves me well, I believe that the size is slightly bigger than the Coyle (but I could be wrong).
I'm sure others will chime in with more detailed info
PostPosted: Fri Feb 08, 2013 10:53 am    Post subject: Reply with quote
Ryosuke Takagi, creator of the Elfin Knights Project once created a kit to upgrade the airsoft into a BR gun, but that was a long time ago, and used opaque wooden look grips. Sidkit metal kits are indeed larger as well.
ItalianNinja86
PostPosted: Fri Feb 08, 2013 11:17 am    Post subject: Reply with quote
If I was to get a sidkit would it work? Or was the base revolver he used larger then the bulldog also?
PostPosted: Sat Feb 09, 2013 4:31 am    Post subject: Reply with quote
Sidkit used Coyle's parts at his base, but the process and material he used created a replica that had parts that grew instead of shrinking from the molding process.
ItalianNinja86
PostPosted: Sat Mar 02, 2013 10:41 am    Post subject: Reply with quote
So I figured I bump this thread with a new question.
I've been thinking about getting the tomensule pro kit since it looks good and the price is right up there with a kit version of the coyle so its pretty affordable.
My question to the experts is would this work for my idea of converting the kanamaru bulldog over to a blaster?
jakob2121
PostPosted: Sat Mar 02, 2013 1:10 pm    Post subject: Reply with quote
Without holding the base gun in my hand its hard to say for certain - and doubly so since we've not actually seen the kit. With either option you're still going to be looking at a separate barrel since both are not actual barrels.
Otherwise, there are a few small mounts you'll have to sort out - and the front trigger area might need to be ground out a bit to make room, but it should work. The Tomenosuke hews extremely close to the original lines.
-J
PostPosted: Sat Mar 02, 2013 1:38 pm    Post subject: Reply with quote
The Tomenosuke Pro kit for the record looks like it will be mostly plastic, and at least not as much metal as a Coyle kit. Still, it is a beautiful highly refined version of the gun, but still pretty much another interpretation of the gun. I think I need one, but also kind of regret not getting a Coyle metal kit, even though I do have many older Coyle versions. If only I had all the money in the world.
The accuracy of the Kanamaru, will have it's own issues. I wish our friends at Elfin Knights checked in more often and could relay information back to Ryosuke to possibly help us out here. I can't remember who it was that was in contact with him offhand.
