Posted: Thu Jun 06, 2013 1:56 pm Post subject: |
There is nothing wrong with recasting a set of grips for your own personal project. Like copying your CD to your iPod to listen to. I am only talking about seeing what people can come up with. I also expect the Tomen guys to okay us making grips since they are not willing. Like Rich said though, and cast from them will likely be a little too small though. I am not worried about people doing runs of these until after the fact, and then they can say "yea", "nay", or "hold on we will make them". There is also nothing holding back someone recreating the grip forms from other means either. If Dave is able to CNC them, or someone wants to sculpt their own, and cast them. The more options at that point the better. I want to see people's imaginations go wild on these.
Posted: Thu Jun 06, 2013 3:51 pm Post subject: |
Does Tomen even have the blessings of the BR property owner to even make these? No where is Blade Runner even mentioned on the box.
The grips also don't have that gentle curve at the top.
I'm still pleased with mine. Can someone PLEASE post how to make them look like glass? I've polished with Novis 2 & 3 forever and they still look like they do straight out of the box.
I was going to send my receiver in to get it milled for the barrel, but Mune said no plans on doing replacement parts. So if something gets lost or damaged, then you are SOL. |
Posted: Thu Jun 06, 2013 4:08 pm Post subject: |
Funny that no one has mentioned actually asking mune if it's ok to recast the grips? I'm sure they wouldn't care as long as they were for owners of the kit.
As for the grips you need to get some super fine sandpaper and wet sand them all over. Then polish them up with a cutting polish like T-Cut. _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Thu Jun 06, 2013 4:16 pm Post subject: |
Andy,
I take your point.
I was thinking more in terms of producing aftermarket replacement grips. I see what you mean, though.
I've been studying the pics of the original and the Tomenosuke grips, and I can see a few things that look different, apart from the colour. I'll need to get mine in front of me and blow up the reference shots to check. Some of the lines look a little off, some of the shapes too. Could be tricks of the light or angles.
Looking forward to seeing them in person. WHEN they get here
Clutch,
There are no 'Official' replica blasters and no licenses have been granted to my knowledge.
As for a high shine on the grips? work up to 1000 grit wet paper then automotive chrome polish and a stiff rag.
Posted: Thu Jun 06, 2013 4:26 pm Post subject: |
| Sandpaper. Ugh... Got my work cut out for me. |
Posted: Thu Jun 06, 2013 4:31 pm Post subject: |
Don't start too coarse if they're pretty smooth already, otherwise you'll be going backwards.
Posted: Thu Jun 06, 2013 4:54 pm Post subject: |
That's why I thought I'd be ok with the plastic polish from the start.  |
Posted: Thu Jun 06, 2013 5:02 pm Post subject: |
It's really hard to suggest a solution without seeing them in person....
Got any pics?
Posted: Thu Jun 06, 2013 6:24 pm Post subject: |
Proper said...
".... As for a high shine on the grips? work up to 1000 grit wet paper then automotive chrome polish and a stiff rag...."
Yep...same here. I used a similar method to this to get a glass-like super clear grip...used wet sanding 600 grit grading up to 2000 paper, then a small Dremel tool cotton-buffing wheel with fine polishing compound.
Posted: Thu Jun 06, 2013 7:30 pm Post subject: |
Guys before you spend hours and hours sanding and polishing these grips, take a little of “Mothers” Mag & Aluminum Polish and rub it on and let dry a little and buff off with a soft clean rag.
I cannot see how you can improve on that.
These grips are fantastic with just a little polish.
Sanding will take them down from where they are out of the box.
Phasepistol told me to try this on mine and it works great, and I just tried it on these grips and it does on them as well.
Posted: Thu Jun 06, 2013 8:12 pm Post subject: |
I don't think Mune wouldn't o.k. people doing a cast of their grip (or even other kinds of grips altogether). It's not as if we're going to make a lot of money out of that.
As for me, I would wait for DaveG and his sculpt and maybe other models as well.  |
DaveG Community Member
Posted: Thu Jun 06, 2013 9:14 pm Post subject: Getting a Grip! |
So here's where I stand, for now, on the issue of making grips, amber, clear, purple or otherwise...
Generally I only make props, or accessories/aftermarket parts for props that I want myself, and which are either unavailable elsewhere, or on which I feel I could do a better job. Since I already have an assembled Pro with the nicer amber grips, I don't need to go to all the (extensive) trouble to mold and cast a set for myself. For the two Tomen kits that I have, one is going to be finished with hardwood grips, the other with clear. To that end, I am working now on the CG model that will be used for milling them on the CNC router. I am planning on offering hardwood grips for sale, like I did for my snub nose.
The clear grips I am going to make will be a one off set milled from clear acrylic, then hand sanded smooth, polished, and re-setup on the CNC for checkering. Very time consuming. I would figure that by the time they are done, a single set of clear grips made this way will have close to 6 hours of labor in them. If I were to sell them, they'd be $300 to $350. this is the same work that would have to be done for a set of patterns to be molded and cast, and since I only need one set, there is no reason for me to invest the additional time and materials. Casting clear materials is to the high standard I established with my Snubby grips is a royal PITA (24 hours per pour/cure cycle and a very high reject rate). The end price for cast clear grips would be very high. I doubt t here would be many sales.
If anyone else wants to take a crack at making grips for sale, clear, amber, purple or otherwise, you have my blessing. But don't recast! Rich, thanks for the offer but I don't really want to make patterns or molds for someone else to cast from.
On top of all this, I've got a s**t load of steel barrels to turn! And a backlog of display stand orders so I don't have the time to pursue this anyway.
Of course, now all I can think about is Andy's idea for tortoise shell grips...
 _________________ Dave
Posted: Thu Jun 06, 2013 9:43 pm Post subject: |
Mune is not the same as Tomenosuke. He is Munegumi from the Hollywood Collectors Gallery, or the group that sells these for Tomenosuke, especially overseas. Tomenosuke is Shinji Nakako, and the builder of the gun is Nobutaka Toku, or Nobu.
I have a feeling they will let us make the grips, and anything else we want to make to customize them. They might want some for themselves too, but if the idea is good they will likely want to make them themselves as well. I am hoping to encourage them to at least think about making this stuff.
Truth is, that I am glad these are not perfect, and I love the fact that we can expand upon them for a long time to come. It makes this an engaging hobby.
darthwolf7 Community Member
Posted: Fri Jun 07, 2013 2:28 am Post subject: |
| I just wish I could afford one of these kits or pros!?! I'm excited seeing all the pictures and upgrading etc...I'm dying to get in on the fun!?!...hopefully someday?! Have fun everyone! |
Posted: Fri Jun 07, 2013 3:30 am Post subject: Re: Getting a Grip! |
| DaveG wrote: |
...Of course, now all I can think about is Andy's idea for tortoise shell grips...
Then my job is done .
Yeah, I did figure these would be a PITA to make. I kind of have no hope of getting them myself, but I figure if a few of us make them for ourselves, it might influence them to make some available for sale at some point. Making the different grip styles may also influence buyers buying extra kits from them to have different variations in their collections. A win-win for them IMHO. That is the beauty of having a raw kit like this, is that it has so much potential.
I know I can live just fine with my "Piss Yellow" grips, and I am trying to see them as closer to the hero, by trying different lighting and background colors, and I can now get it closer than I had before. I also know if I don't drink too much water my piss can get darker too I have heard of people using future floor acrylic polish mixed with dyes in an airbrush to color clear parts before. Still I am just going to see if I can get more used to them just in case I am jaded by earlier grip colors that have influenced me, and my preferences. Of course a set of pearl grips would be sweet too
Posted: Fri Jun 07, 2013 4:17 am Post subject: |
Dave,
Thanks for chiming in and making your position clear. I wanted to wait until you did to see where you were.
I can completely see and understand your viewpoint. I can also see why you wouldn't be interested in anyone else casting grips from your patterns.
I really can't see Tomenosuke granting 'permission' for people to cast grips to fit their model. I doubt they would have any involvement with this.
However, someone making grips which happen to fit their blaster kit is really none of their concern, and I expect they'd see it that way too.
The idea of new amber grips, from an original set of master patterns is the same as Dave's steel barrels. An aftermarket, but very welcome addition to an already excellent product.
I'll take a look at this.
Posted: Fri Jun 07, 2013 5:38 am Post subject: |
I will be dropping out for a day or two as I change out my bad Foxconn motherboard.
See you on the other side.
PS I think Foxconn is a low price and low quality board, beware... _________________ I never have enough time to do all I want to do! |
Posted: Fri Jun 07, 2013 9:29 am Post subject: |
| proper wrote: | | I really can't see Tomenosuke granting 'permission' for people to cast grips to fit their model. I doubt they would have any involvement with this. |
The only permission Tomenosuke could grant would be to mold their grips and recast them, which I also doubt they would do. As to other grips made from scratch to fit their blaster, they wouls have no say in it, though I would hope they would view it as a good thing.
As Rich has mentioned, you get a generational shrinkage when recasting, a little bit in the rubber mold and even more in the resin pour, especially clear resins. This will make recast grips hard to fit, especially the getting the holes to align. _________________ Dave
Posted: Fri Jun 07, 2013 9:37 am Post subject: |
Dave,
Thanks for the input.
I have absolutely no plans to recast the Tomenosuke grips, as I stated above, so shrinkage won't be an issue.
The grip models will be new originals.
Moulding and casting resins has been part of my day job for over two decades. I use a medical grade Platinum cure rubber for moulding, which has near zero shrinkage, regardless.
The bigger shrinkage is from the resin. But low exotherm urethanes are pretty good these days. I have a good supplier here.
I'll look at costing this and see where we go.....
Posted: Fri Jun 07, 2013 10:26 am Post subject: |
Thanks Dave for the feed-back and Karl, Rich for all of this.
Aftermarket will be the way to go...depending on cost of course.
I'm looking forward to see one of those gun transformed into a chrome/transparent grip done by one, or many, of our members here  |
