Posted: Fri Jun 07, 2013 10:46 am Post subject: |
I am glad that a couple of people have stepped up to take care of this.
I was offering only because I felt I might be one of the few that could do the grips.
But I am more than glad to step aside as with my current health problems it would have been hard and taken a little long for me to do.
PS Got Doctor's appointment this AM so will start on computer after it. See you. _________________ I never have enough time to do all I want to do!
Posted: Fri Jun 07, 2013 12:20 pm Post subject: |
Andy, get some of that rubylith stuff, cut it to the shape of the grip and sandwich it between the grip and the frame. It'd would have to warm it up a little I would think.
Posted: Fri Jun 07, 2013 5:00 pm Post subject: |
anyone know why the bolt lever end rod (with pointy bit at end) is metal? and if so how would I get it back to its base metal finish?
Also I noticed the tube that connects the mag housing to the barrel at the end is black plastic. Was this metal on the hero? if so can anyone suggest a good metal replacement? _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Fri Jun 07, 2013 7:34 pm Post subject: |
| clutch wrote: | | Can someone PLEASE post how to make them look like glass? I've polished with Novis 2 & 3 forever and they still look like they do straight out of the box. |
The trick is to take the grips off and polish the back sides.
Also I use Mother's Mag polish, which is awesome. Turns aluminum into "chrome".
Karl |
Posted: Sat Jun 08, 2013 3:26 am Post subject: |
I AM BACK!
New ASUS Motherboard is HOT...
First it forced me to upgrade to DDR3 @ 1833HZ from my old 800HZ DDR2.
Then I found that it runs SATA 6 over my old board running only SATA 3.
And lastly I have not done a new install I just run the new driver disk for the MB and it set its self up.
Posted: Sat Jun 08, 2013 11:19 am Post subject: |
Glad to see all that tech stuff worked well Rich  |
DaveG Community Member
Posted: Sat Jun 08, 2013 11:26 am Post subject: |
DId you upgrade your Oscillation Overthruster? _________________ Dave
Posted: Sat Jun 08, 2013 11:34 am Post subject: |
No I already had a AMD Four Peg Oscillating unit Running at over 2.4 GHZs, but now know the main device it was driving was not a good a match as was needed.
And Luckly my recorder devices were already of the higher speed and again the main unit was holding them back as well.
