Sarednab Community Member
Posted: Thu Apr 16, 2015 12:50 pm Post subject: |
Ahahahahha! Thanks guys!
We are proud for this run  |
Nexus7 Community Member
Posted: Thu Apr 16, 2015 4:26 pm Post subject: |
| Anyone recommend the best type of glue to adhere the ribbon/seal together? |
Replicant 13 Community Member
Posted: Thu Apr 16, 2015 10:06 pm Post subject: STICKY BUSINESS |
Others may disagree, but here's some suggestions, Nexus.
There are several ways to go here, depending on skill and just how permanent you want this to be . . .
It's always best to test anything out first on something not so valuable. Test the position and fit, and test the glue on something disposable.
SUPER GLUES
There's always the Super Glues, but they can be tricky. There are various brands, but hobby stores also generally carry differing grades/viscocities. My local hobby shop carries about 4 grades: the regular, VERY fluid version - using capillary action it flows readily into every crack and crevice - great for styrene, but it can get away from you and you can wind up with your fingers glued together. I would advise against that one. And then there are the others - thicker versions that are not so fluid and take a bit longer to cure. If you are hesitant, the thicker the better. There are about 3 or 4 levels here.
Here's a link to one thicker super glue:
http://www.chasedentalsupply.com/insta-cure-gap-filing.aspx?gclid=CjwKEAjwu72pBRC9hsn2-e34vRUSJACnSYsTIYh2_sUeYdUi4_42Fg2Of76Fh9gQndi5THk8Tr9OnRoClU_w_wcB
EPOXIES
Next are the epoxies, usually a two part goop with an applicator or that you mix by hand. Again, there are a variety and they range in application and curing time. Read the labels and see what each is recommend for: wood, metal, glass, PVC plastics. You will want what best suits the materials here.
RUBBER CEMENT
Even something like rubber cement might work, if you don't what such a permanent bond.
PUTTIES
Lastly there are adhesive putties, mixed by hand in equal amounts, parts A & B, but these vary as well in their adhesive qualities and take about an hour to harden.
To apply glues I usually use a small brush that can be discarded. With shorter working times this seems to afford the most control. Squirting adhesive from a tube can be disastrous!
Again, be patient and test it first.
Hope this helps. - R13 _________________
Posted: Fri Apr 17, 2015 5:08 pm Post subject: |
Great post. Thanks for the reply. I tested a bit of the more watery super glue on the ribbon fabric and of course it just soaked right through it. I may end up going the rubber cement route.
Thanks, again! |
LadyVengeance
Posted: Mon Apr 20, 2015 12:37 pm Post subject: |
Bottle arrived in perfect condition! I had previously owned the first run that was made a couple of years back but it was cracked due to shipping. The Murano glass on this one is far more superior than my old one in every way. Very happy with this purchase, I'm sure whoever purchases this bottle will see how beautiful and sold this craftsmanship is and WON'T be disappointed. This is a heavy bottle which shows it's quality. A+ Seller! Thanks again!
Here's a picture of my fiancé adding the labels.
Posted: Tue Apr 21, 2015 4:20 pm Post subject: |
As glue you can also use egg white, works a charm, transparent and easy to remove if need be  |
Posted: Tue Apr 21, 2015 5:29 pm Post subject: |
| Wow. I had no idea! Thanks! |
Posted: Tue Apr 21, 2015 9:09 pm Post subject: GLUE HUMOR |
And it's less fattening than super glue . . . _________________
Posted: Thu Apr 23, 2015 4:15 pm Post subject: |
Indeed, full of proteins  |
Sheehan Community Member
Posted: Sat Apr 25, 2015 4:53 am Post subject: |
My bottle arrived yesterday. It's an absolute beauty. Already full to the brim with Black Label, and has found a nice spot in my collection.
 _________________ You've done a man's job, sir. |
Posted: Sat Apr 25, 2015 4:57 am Post subject: |
Well I may as well show the bottles new home in context.
Posted: Sat Apr 25, 2015 9:52 am Post subject: |
| A fine addition to an already amazing collection! |
Ki-Djowac Community Member
Posted: Sat Apr 25, 2015 10:16 am Post subject: |
Got Mine, bottle quality is epic. Truly one of the best purchases i've ever made
Here it is :
Posted: Sat Apr 25, 2015 10:17 am Post subject: |
I'm very happy that everyone love his bottle! We are proud for this run!
Thanks again guys  |
Posted: Sat Apr 25, 2015 11:48 am Post subject: |
| Looks great! |
Posted: Sun Apr 26, 2015 10:43 am Post subject: |
Is it possible that I read somewhere that extra labels will be offered? Anyway I'm in for one extra label set  _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Sun Apr 26, 2015 10:45 am Post subject: |
| Buch wrote: | Is it possible that I read somewhere that extra labels will be offered? Anyway I'm in for one extra label set  |
Now we are 7 in list for extra label (50$). If we'll arrive to 50 people in list we could produce it  |
Posted: Sun Apr 26, 2015 11:37 am Post subject: |
| Sarednab wrote: | | Buch wrote: | Is it possible that I read somewhere that extra labels will be offered? Anyway I'm in for one extra label set  |
Hope dies last  _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Sun Apr 26, 2015 9:50 pm Post subject: |
A few more shots (taken with my iPhone sorry!)
Posted: Tue Apr 28, 2015 6:53 pm Post subject: |
Great collections guys and great pics as well...keep 'em comin'  |
