Grip polishing techniques
PostPosted: Thu Sep 25, 2014 9:08 am    Post subject: Grip polishing techniques Reply with quote
Can people please post the materials and techniques for getting grips shiny as glass? Rich? Anyone? I have Novus but that doesn't seem to work.
PostPosted: Thu Sep 25, 2014 1:27 pm    Post subject: Reply with quote
Sandpaper progression 320 - 1500 also must be wet to wash away grit accumulated.
Then airbrush or carefully hand brush on some Future floor polish on the backside of the grips and allow them to dry on a level flat surface. The future will fill in any minor scratches from the sanding.
cratercritter
PostPosted: Thu Sep 25, 2014 5:37 pm    Post subject: Reply with quote
Depends on the condition of the existing grips to start with. Sometimes you can start with 600 or 800 grit paper and work your way to the more smoother paper. Like Hirohawa said...make sure you use 'wet' sanding method with paper grit size progression. I progress the paper up to 2000 grit fineness. Then I use a dremel tool with polishing wheel and polishing compound....gently as high speed buffing wheels can cook or burn the plastic if you press or work the plastic too much.
Finally...I use the fine grade Novus polish by hand for finishing.
It was a bit of trial and error for me until I found the best methods that work for this type of plastic/resin material. There is more than one way to polish these. I am sure others will use similar or different methods.... the key is to avoid harsh solvents or harsh chemicals. If use sand paper...use progressive grit sizing, preferably a wet method, to a very fine grade, so that it will make the final polishing /finishing stage easier.
I have never tried the Future floor polish method. Interesting.
PostPosted: Thu Sep 25, 2014 7:10 pm    Post subject: Reply with quote
On mine I use a BIG 6 inch buffer wheel on a big grinder, and white polishing compound and have at it.
My grips come out of the mold fairly nice so I don't do any sanding..and as I use a great grade of plastic they do not melt or burn.
Once I have done the buffing polish I the use Mother Mag wheel polish to finish them off and to put a super fine coat of wax on them.
spoudastis
PostPosted: Mon May 04, 2015 12:09 am    Post subject: Reply with quote
Great tips, I'll be finishing mine up soon and this will really help.
corellian77
PostPosted: Wed May 06, 2015 11:05 pm    Post subject: Reply with quote
Please let us know which techniques you ended up using, and post pics!
PostPosted: Tue May 26, 2015 9:58 pm    Post subject: Reply with quote
What I've done is polish the backs of the grips (and sometimes the smooth edge (but not the waffle texture) on the front, with Mother's Mag chrome polish.
DARKVIEW
PostPosted: Fri Aug 07, 2015 8:24 am    Post subject: Reply with quote
l hear brasso can be used on the grips to make a used look in the pattern!, is that brass or crome brasso l wonder?
https://www.facebook.com/darkview
http://twitter.com/darkview
PostPosted: Fri Aug 07, 2015 9:53 am    Post subject: Reply with quote
I've used Brasso, it works impeccable.... It both polishes the plastic and leaves the desired trace on the grip's texture.
This one:
http://homebase.scene7.com/is/image/homebase/116194_R_Z001?$LISTER$&wid=420&hei=420
DARKVIEW
PostPosted: Fri Aug 07, 2015 9:58 am    Post subject: Reply with quote
Arh thanks dude, found some in my cupboard ...out of date by 12 years but should still work Wink
