SidKit Blaster hammer/trigger/Chamber info
Goto page Previous  1, 2, 3
DARKVIEW
PostPosted: Wed Sep 16, 2015 9:29 am    Post subject: Reply with quote
Cheers RIch, mine didn't have guide holes on those inner parts so i didnt know where to drill!! (some are there on other parts to guide, some not! Abouts the gun).
https://www.facebook.com/darkview
http://twitter.com/darkview
PostPosted: Wed Sep 16, 2015 9:32 am    Post subject: Reply with quote
Well are you showing pictures of YOUR model??
R
DARKVIEW
PostPosted: Wed Sep 16, 2015 9:44 am    Post subject: Reply with quote
Hold on fella, lm going as fast as I can . Drilled holes now...that were not there...
PostPosted: Wed Sep 16, 2015 9:52 am    Post subject: Reply with quote
OK first you want to cut the grip frame level with the grips.
Next I see there is a pair of holes in the rear cap and the back of the bolt.
You may have to glue a 4/40 nut inside the back of the bolt so you can thread a round head 4/40 screw though the rear cap to the bolts.
Next see the dimple above notch behind the safety?? It is where you drill with a #43 drill and thread for a another 4/40 round head screw.
This screw has to be just long enough to fit though the slot but not bind the bolt.
The safety is held by a small round head screw not that allen cap screw.
Check out the picture I posted for these details.
DARKVIEW
PostPosted: Wed Sep 16, 2015 10:11 am    Post subject: Reply with quote
Cheers will do that when lve a bit time. (Wifey wants her chest of drawers fixed now!!!). Tut! One good thing is apart from my created weathering while disassembly/construction etc.. I create natural weathering from handling it etc and of course being careful of the taped threads wearing out etc.. When it's finished it gets it's final weathering coat/ bluing etc
PostPosted: Wed Sep 16, 2015 10:13 am    Post subject: Reply with quote
OK Have fun storming the castle...
PostPosted: Wed Sep 16, 2015 10:39 am    Post subject: Reply with quote
Thought l'd show people the LED Casing for a OFFWORLD prebuilt (top left) & my SidKit Worldcon right below...
I've often wondered if the Offworld electronics would fit in a Sidkit. IMO, so much more professional...
DARKVIEW
PostPosted: Wed Sep 16, 2015 10:48 am    Post subject: Reply with quote
Yeah!! I've tried & it fits, not perfect but not to shoddy main difference is the main underside info & detail... (REM222 looks font different & Steyr missing in center logo) and its silky production manufacturing coat but its mainly simple,well done LED systems a plus...still back to soldering & good old fashion messy wiring...erhhh!!!
Left: OFFWORLD. Right: Sidkit.
PostPosted: Wed Sep 16, 2015 11:03 am    Post subject: Reply with quote
I was referring to just the electronics fitting into a Sidkit ammo clip..
DARKVIEW
PostPosted: Wed Sep 16, 2015 11:11 am    Post subject: Reply with quote
I see...I'd hate to strip a perfectly expenise light system from a OFFWORLD to a Sidkit build . But electronics experts should know the parts etc to replicate... A tad out of my jurisdiction... I want more lights....fella;-)
PostPosted: Wed Sep 16, 2015 12:21 pm    Post subject: Reply with quote
I agree those button cells do not have much life, and it is fairly easy to wire in the LEDs.
http://s922.photobucket.com/user/racprops/library/Propsummit%20SE%20Blade%20Runner%20kit%20instructions/Ammo%20housing%20and%20clip?sort=3&page=1
DARKVIEW
PostPosted: Mon Sep 21, 2015 8:09 am    Post subject: Reply with quote
I'm going to get back to the lighting of this Sidkit later, l want to understand all involved with it first & possible other options like OFFWORLD!!?!!
Wishing I'd titled this build SIDKIT WORLDCON BUILD (pros & cons).
Anyway I've been studying many shots of the Karl Tate shots on RPF gallery... Just to create a few more details to the original movie prop...(thanks to them). I want mine total grunge/knocks/scrapes & possibly rusted like the hero gun...tho I do think the rust is its years since the movie!!. That l build on come the time.
The top 2 show the trigger pins, l sanded the cooper ones down you get and then added with a brush the bluing agent... Now l know the originals look almost faded & none existent but l like them, later should l want l can fill the 'holes'.
Bottom 2 show the curious case of the slight bit of wood (it seems) at the end receiver bolt Alun screw!!! so a tad of cocktail stick recreates that!!
Note:I've to warm up the main bottom arch-sides that hold the back receiver bolt part to fit around it more snug...that's later when near complete!! And to anyone doing the main bluing at 1st be careful of these bottom sides when treating/washing/wool sanding etc as they can bend without you really noticing due to there thin arch sides!!!
PostPosted: Mon Sep 21, 2015 11:22 am    Post subject: Reply with quote
Very invigorating seeing this build as you're working, cheers for sharing.
I think I used a matchstick for the receiver and also one in the rear of the grip - so great to see your solution.
If I may can I suggest that you replace the hollow trigger tubes with solid rods and round off the head of the screw on your thumb release so that its not so clearly an alien part as it is on the Sid?
Looking forward to seeing how this progresses.
High regards
MARK
DARKVIEW
PostPosted: Mon Sep 21, 2015 2:49 pm    Post subject: Reply with quote
Cheers Staar, going to get some solid rods at some point or fill in mine!!
Wonder what the hell the bit of wood in the alun screw was supposed to be about!!? I reckon a mistake...
PostPosted: Mon Sep 21, 2015 2:55 pm    Post subject: Reply with quote
I think it was just mud.
The Blaster as found was dirty.
The grips had mud in the pattern.
DARKVIEW
PostPosted: Mon Sep 21, 2015 3:07 pm    Post subject: Reply with quote
Now that's funny, looks more wood than mud! But who knows who owned the original all these years then?
PostPosted: Sat Sep 26, 2015 8:07 am    Post subject: Reply with quote
TFS your build DARKVIEW. Looking good so far and glad you're putting little details in as to make it closer to the original
DARKVIEW
PostPosted: Sat Sep 26, 2015 8:28 am    Post subject: Reply with quote
Cheers. lve done it a tad darker on the bluing. Now to consider the rusts next but unsure weather to go down that path...
PostPosted: Sat Sep 26, 2015 2:44 pm    Post subject: Reply with quote
I think Rich is using the word "mud" as a term for plaster as the blaster had a lot of residue from going through the bathroom wall in the Batty chase sequence.
Page 3 of 3
