ogrotesque1 Community Member
Joined: 30 Sep 2016 Posts: 176 Location: La Palma, CA
Posted: Sun Aug 06, 2017 4:33 pm Post subject: Tomenosuke Blaster loose swinging Bolt fix remedy? |
Has anybody found a way to make their Tomenosuke Bolt from swinging loosely out? There's got to be some type of simple remedy for this!? Mine is so loose and always opens if I lean the Blaster to the right side, bugs me so much! Thank you in advance to whoever can help me on this. Here's some more pics of my live-fire conversion with a freshly reblued receiver!
Damion
http://propsummit.com/upload/2816/img_8351.jpg _________________ Damion: ogrotesque1 |
Posted: Mon Aug 07, 2017 8:54 am Post subject: |
Nice weapon you have there mate One of our member (who doesn't post here anymore)had some kind of rubber sleeve/tube around the pin inside the Steyr part...it worked for him  |
Posted: Mon Aug 07, 2017 9:51 am Post subject: |
You could write to Tomenosuke Company I guess. They might help.
Their Tom Pro Blasters (completed version) bolt levers did not swing out so easily and are quite stable for blaster models manufactured after the 2013/2014 year onwards. I am not sure what they did to reduce or stop/rectify this "behaviour".
Like Joberg said, I too remember a few years ago one of the members here or on the RPF did a mod to his blaster using a washer of some sort inside the steyr receiver's front end assembly, behind the 'fixed end cap' and the moving bolt.
Example from the RPF:
https://www.therpf.com/showthread.php?t=174014&page=25
https://www.therpf.com/showthread.php?t=174014&page=26 |
Posted: Mon Aug 07, 2017 1:25 pm Post subject: |
Hey, thank you guys for the links! There I almost tried gluing the cut rubber washer to go behind the Steyr Bolt Cap, but I kept reading and found an RPF member that said he used a really small nitrile o-ring on the screw after it is placed inside the Bolt Sleeve then threaded into the Bolt itself. Worked like a charm! I literally have zero room for anything that can go on the front pin otherwise but, the other method worked perfectly!
Thanks again fellas,
Damion _________________ Damion: ogrotesque1 |
Posted: Mon Aug 07, 2017 2:54 pm Post subject: |
The O-ring method sounds interesting. Hard to picture what is going on there, but if it works...cool.  |
Posted: Mon Aug 07, 2017 3:33 pm Post subject: |
cratercritter wrote: | The O-ring method sounds interesting. Hard to picture what is going on there, but if it works...cool.  |
Maybe this photo will help you understand a bit more clearly? It actually doesn't get any easier than this, very simple and seems to work quite well.
http://propsummit.com/upload/2816/img_8364.jpg
Now, you just screw it in her and she's fixed! Works on almost all females. Sorry, had to go there....my bad!? _________________ Damion: ogrotesque1 |
Posted: Mon Aug 07, 2017 11:04 pm Post subject: |
Thanks for the pic.  |
Posted: Tue Aug 08, 2017 2:24 am Post subject: |
cratercritter wrote: | Thanks for the pic.  |
No worries critter! _________________ Damion: ogrotesque1 |
Posted: Tue Aug 08, 2017 4:50 am Post subject: |
Funnily enough the Tomenosuke copies the hero 100% in this regard because the bolt on the hero is extremely loose... _________________
Posted: Tue Aug 08, 2017 6:39 am Post subject: |
Problem fixed Thanks for the pic! |
