Aluminum Sight Rods on Etsy
ogrotesque1
PostPosted: Sat May 25, 2019 9:17 am    Post subject: Aluminum Sight Rods on Etsy Reply with quote
Hey Blade Runners,
There’s a seller by the name of DesignbySamuel on Etsy that machines Laser Sight Rods out of Aluminum! We chatted and I asked him if he could make them hollow and match the Tomenosuke hole pattern, to which he responded back with a YES! He just needs the Sight Rod’s schematics or blue print for the correct hole pattern and threading. I’m sure he can do other hole patterns as well. He’s not expensive at all either! I know somebody on here has the blue print for Tomenosuke’s Sight Rod? I sure could use it to get a couple made from him? Thanks,
Damion
Damion: ogrotesque1
PostPosted: Sat May 25, 2019 4:36 pm    Post subject: Reply with quote
I could send him one if that helps.
ogrotesque1
PostPosted: Sat May 25, 2019 5:07 pm    Post subject: Reply with quote
That’s a great idea Steve! I’ll let him know you’ll be in touch with him about it. He seems pretty enthused about machining some up. Thanks!
Damion
Damion: ogrotesque1
