Posted: Mon Aug 16, 2010 9:56 am Post subject: |
| I think it's still a one-off made for the film; you can see in the previous pics posted by Nick that when the case is closed all the way, there's still a gap between the two parts (at the bottom). Usually, these cases are either made with ABS plastics or if not, an aluminum lip is placed around the two parts (top/bottom) to make sure the case is tight shut. |
Posted: Tue Aug 31, 2010 6:46 am Post subject: |
Bumperoo! Hope that more pics are going to be posted of the case...as well as the VK machine itself  |
propsjonnyb Community Member
Posted: Tue Aug 31, 2010 7:04 am Post subject: |
| Agree, with you , this should be the easiest conversion , I'm just going to cover the Haliburton 'a la offword66' as it'll be quik to convert and finish can anyone confirm that the top matches ( is a mirror) of the top? |
Posted: Tue Aug 31, 2010 4:10 pm Post subject: |
| Cannot confirm if no more pics are surfacing...unless the bottom is the same as the pic showing Deckard exiting his car in front of his apt. |
hole dweller Community Member
Posted: Wed Sep 08, 2010 5:09 am Post subject: |
Hey guys
I use to work in video production and that case looks like a case for lighting equipment.
http://www.lowel.com/cases.html
The styles have changed over the years but I think and older case may be what you are looking for.
Check ebay.......
Gary _________________ WWW.GFORCEMODELS.COM |
Posted: Wed Sep 08, 2010 6:49 am Post subject: |
In BR if you hold the case normaly, the lines are horizontal...on the Lowel's they are vertical...the search continues  |
nickdaring Community Member
Posted: Fri Feb 17, 2012 2:37 pm Post subject: |
Good catch Nick!  |
Posted: Tue Apr 02, 2013 11:00 pm Post subject: |
| Thought I'd bump this back up since there's been so much VK scholarship work going on. |
Posted: Wed Apr 03, 2013 7:00 am Post subject: |
Nick, I started a V.K. case project on the next thread  |
