modifying the sidkit barrel?
Goto page Previous  1, 2
PostPosted: Mon Jan 12, 2009 4:01 pm    Post subject: Reply with quote
I could never do that. My girlfriend would skin me alive if she walked into the kitchen and I was liquifying metal.
Mind you, we have a brand new stove, so . . .
chew
PostPosted: Mon Jan 12, 2009 7:30 pm    Post subject: Reply with quote
Yeah but it probably gets so much hotter so much quicker.
My wife works at a jewelry company she was totally excited about the idea!! Cool
I just do eyes.
chew
PostPosted: Mon Jan 12, 2009 7:33 pm    Post subject: Reply with quote
BeastMaster wrote:
look forward to seeing that Smile I got a mate who has a drill press, so might be able to just drill out the hole when done.
did the metal not stick to the aluminium?
Nope- it peeled right off. just make sure to bury as much of the barrel in sand as possible so it has support!
I just do eyes.
PostPosted: Tue Jan 13, 2009 10:39 am    Post subject: Reply with quote
had a go with this just now. works a treat! Smile there are a few gaps that will need filling with the soldering iron but it's pretty much solid.
The diameter of the barrel is the same as a one penny, so I used that to flatten out the end.
nice one chew Wink
chew
PostPosted: Tue Jan 13, 2009 8:00 pm    Post subject: Reply with quote
WELL DONE!
That looks so much better than mine did pre-grind. the penny was a great idea!
its crazy how the exterior of the barrel changes color/finish from the heat right?!? You can clearly see how far you filled the end.
What did you use to melt/pour?
I just do eyes.
PostPosted: Wed Jan 14, 2009 7:02 am    Post subject: Reply with quote
cheers chew Smile
yeah the metal goes all white and powdery. it was also still super hot for a while after pouring, so had to let it cool a bit. I used a mini ladle to pour, heated on an electric hob.
here it is after the grind
the extra length makes a huge difference to the accuracy. I'm just a bit concerned as to going about the bevel. I was thinking of securing it in a vice to stop it moving up and down and rotate it into the dremel cutter, something like that.
PostPosted: Wed Jan 14, 2009 8:16 am    Post subject: Reply with quote
It looks very good Beast!
Hasenbrau
PostPosted: Wed Jan 14, 2009 12:31 pm    Post subject: Reply with quote
Great works guys. I can't wait to see you get that bevel in there.
PostPosted: Sun Jan 18, 2009 5:51 pm    Post subject: Reply with quote
this is pretty much done now. I ended up drilling the hole with a hand drill and filing it out. I tried to dremel the bevel but its really tricky to control, so I filed it by hand.
not as neat as I would have liked it to be, but anything other than that "cap gun" barrel as OB likes to call it Wink
chew
PostPosted: Sun Jan 18, 2009 6:42 pm    Post subject: Reply with quote
looks great! after seeing yours and feeling I'd ground mine too thin again I re-poured a third time....
what type of drill bit did you you use?
I just do eyes.
Hasenbrau
PostPosted: Sun Jan 18, 2009 9:31 pm    Post subject: Reply with quote
Very nice work BeastMaster, you can't really tell it was done by hand and like you said; quite the improvement over the stock kit barrel.
PostPosted: Mon Jan 19, 2009 7:09 am    Post subject: Reply with quote
cheers guys Smile
chew: I think the drill bit I used was around 3/8 or 9.5. It was basically smaller than the hole I wanted as the biggest drill I had was too blunt.
so basically used this drill and filed out the hole until it measured around 11mm in diameter.
PostPosted: Mon Jan 19, 2009 8:22 am    Post subject: Reply with quote
Love it beast! Very good job.
PostPosted: Mon Jan 19, 2009 11:13 am    Post subject: Reply with quote
thanks joberg Smile
I am also in the process of modifying other parts of the blaster this way. I'll post some updates in the blog when they're done.
panzerrune
PostPosted: Wed Jan 21, 2009 5:49 pm    Post subject: Reply with quote
That looks great! My SIDKIT is competely finished and together, so for me to do that would require taking the kit apart, fixing the barrel, having it refinished and than reassembling. Nice work and you proved it can be done, but it to me is not worth the work of what i would have to do to get it to look like yours. If mine was not assembled yet i would do it as the SIDKIT is really messy when it comes to that area of the gun, sad it was done so sloppy when it came to the barrel. Sad Considering how much work was put into the rest of the SIDKIT it is weird that nothing was done to recreate the business end of the gun accurately per the WC HP!?!?!?!?
Thanks!
PostPosted: Thu Jan 22, 2009 10:58 am    Post subject: Reply with quote
I wish I contributed more feedback when he was documenting his WC kit build. I remember being more pre-occupied with the ammo housing not being plastic and didnt take the barrel into consideration. though I realise now its a crucial asthetic in defining the overall shape of the blaster. it's like putting a different nose on a famous actor! Rolling Eyes
Page 2 of 2
